5 Pages <12345>
The Royal Sun build diary by Jase Options
#41 Posted : 17 July 2016 09:02:12
Pack 2 has now landed so on with the build.
Again I have chosen to go slightly out of the instruction sequence, preferring to get all the frames assembled and false decks in.
my aft section of the false keel was slightly warped at the joint point so I had to heavily clamp the area to straighten it, worked a treat.
the rest of the ribs and lower/upper false decks were fitted.
I have also fitted the bowsprit deck.
I have installed only 2 of the three upper fore deck beams so they are not in the way of further planking
I have also built up the first bulkhead as per the instructions, you will need 4 of the strips to cover the bulkhead. once done and sanded this was sealed with a matt varnish.
[img]http://i1160.photobucket.com/albums/q488/jasonport70/IMG_1594_zpsvlaiyf44.jpg/img]
my next step is to complete the deck planking of the upper gun deck
more soon
#42 Posted : 17 July 2016 09:16:52
Nice update Jase looking forward to the next one
#43 Posted : 17 July 2016 10:55:21
She's looking good Jase, coming along nicely...
#44 Posted : 17 July 2016 12:51:18
#45 Posted : 17 July 2016 12:59:43
Nicely taking shape though a long way yet to go. Wonder how many will actually complete this kit inside 12 months as it would normally be a 140 week rollout.
#46 Posted : 17 July 2016 17:02:57
Thanks all for looking in.
As for getting it done in 12 months I am going to do my best but planking and rigging cap be a slow process
#47 Posted : 18 July 2016 11:39:00
Hi jase, looking really good.coming on a treat.
#48 Posted : 19 July 2016 20:05:40
thanks I am enjoying it
J
Gibbo
#49 Posted : 20 July 2016 00:59:02
Very nicely done with the thread caulking Jase, not something i've seen before, i'm very impressed with that.
Paul
kpnuts
#50 Posted : 20 July 2016 06:41:25
That's looking very impressive.
#51 Posted : 20 July 2016 19:05:50
Paul
Its a little time consuming but the look is worth it I think. You cannot sand the deck as that can fray the cotton so you have to carefully scrape the decks with a razor
#52 Posted : 20 July 2016 19:09:20
Brilliant effect on the deck, it will look fantastic when its finished!
greyhawk
#53 Posted : 20 July 2016 21:21:45
Now that I too have a Soleil Royal in hand, I'm going to go ahead and blatantly steal all of your ideas for this build.
Not the thread caulking though, I need to stay sane a little bit longer.
What I'm trying to say is your build is brilliant.
#54 Posted : 20 July 2016 22:41:07
Be good to see your build log start Greyhawk now u have the parts. Just remember to put the frames in the correct places :D
michael.rolph
#55 Posted : 21 July 2016 08:38:10
Sanity is overrated
#56 Posted : 21 July 2016 14:25:01
Looking like great progress Jase.
Is that thread you are using between the planks? Looks like a very slow and tedious process but gives a really nice finished by the look of it.
#57 Posted : 21 July 2016 21:55:15
Hi Jase.
Looking very nice. Look forward to seeing your progress.
Ian
#58 Posted : 21 July 2016 22:05:01
Thanks all for looking in and the comments.
Yes it is thread 0.25mm. it is a bit tedious but that is why i am doing the whole deck length in one go. this allows you to run a length of thread the full length of the deck in one go, with only the need to cut short lengths for the butt joints. about half an hour for one full length of planks, but you need to run two lengths of planks at a time to keep them straight, if that makes sense? All in all about 14 hours estimated to plank the full deck.
As for sanity I spend my free time sat in an attic gluing tiny bits of wood, plastic and metal together, think everybody on this forum must have something loose somewhere, but that's just how I like it.
Gibbo
#59 Posted : 21 July 2016 23:57:21
Hi jase
How thick are the planks that you are using ?
#60 Posted : 25 July 2016 21:23:00
Gibbo wrote:
Hi jase
Hi Gibbo, the planks are 0.5.
J
5 Pages <12345>
