 Rank: Beginner Level 1 Groups: Registered
Appologies if this is the wrong place for this but I'm confused...not difficult I know. The parts that came with issue 15 were 31 through to 34 not as stated 30, a and b and 32 through to 34. Not a problem with part 31 and the support for the gallies and officers cabins. but where do parts 34 (2 off) and parts 32 (10 off) fit. It's not very clear.
Thanks in advance. Keithp
Hi Keith,
You don't install the #32 parts (gallery supports) or the the two #34 parts (stern frame halves) until issue 18.
Ah many thanks Mr T. Not read up that far yet, was just doing a dry run/fit  I'll get that issue opened pronto Regards Keithp
Joined: 21/08/2010 Posts: 35 Points: 110 Location: Now in Berlin, Germany
Hi, don't worry had same question and learned to fall behind with construction is a good thing. At the moment I am only reading ca 10 magazines in advance and voila new details revealed about anchors etc. My tip, wait, read, wait read and then move slowly forward with model build. However mag 15 -18 was really confusing.
