Torro M16 Haltrack Elmod Upgrade Options
kenjara
#1 Posted : 13 July 2016 12:32:14
Not sure if anyone else has or been tempted by this model before but being the only 1/16 RTR halftrack around I picked one up recently.
The model itself is good for the price but the electronics stink so I decided to upgrade it with the elmod board. The funny thing is the little circuit board actually cost more than the model but it turned out to be worth it.
I have come across elmod boards before for Heng Long tanks but they always seemed expensive for what they do.
The elmod for this model adds:
Start up and shut down engine functionality and sounds.
2 aircraft overhead sound bites.
Engine sounds.
Physics simulation (acceleration gear changes etc)
Brake lights when stopping.
Better light pulsing on AA gun.
Better AA gun movement.
Ability to use custom radio equipment.
The model itself looks great, the gun has 360 degree rotation and a good level of elevation. The issue with this model comes from the electronics. Its not 2.4Ghz and only has about a 2 metre radio range.
The model is made to take 8 AA batteries or a small size 2x2 9.6v nimh pack. I did not have such a pack so I went with AA batteries for the first run. The speed was good but the runtime was poor making it an expensive run on non rechargeable batteries.
Next I went to eBay to find a 2x2 9.6 pack. This was bigger than the official 9.6 pack from Torro so I had to begin my destruction of the model.
The AA battery springs and plastic dividers were preventing the battery from fitting into the compartment.
I got some pliers out and started cutting away at things until the pack fit. Next I tested the battery. I was disappointed to see the lower voltage from the rechargeable cells caused a drop in speed.
Next it was time to start working on fitting the elmod. To reveal the electronics the AA gun has to be removed.
There are 2 screws that needed removing hidden under some ammo cases and a radio. These items were simply gently snapped off revealing the screws.
The four screws of the gun base were removed to gain access to the electronics.
With the screws of the gun base removed the gun was disconnected from the circuit board.
The original board and speaker.
The original board is removed and replace with the elmod board. The elmod connects to standard RC receivers, has a volume knob and SD card to customise sounds. It also has a connector so that the board can be connected to a PC and parameters adjusted.
The elmod requires a 4 channel radio setup so I brought an AR400 receiver to use with a helicopter transmitter I own. At this point I tested the model but broke the stock speaker after turning the volume up on the elmod board.
With the stock speaker broken I removed it and replaced it with a speaker from Maplin.
Next I used a reamer to make  some holes in the base to feed the speaker and reciever cables through.
Using double sided tape I fitted the receiver and speaker to space behind the drivers seat.
I used a camo net to cover the speaker and receiver. I used small pieces of tape to shape the netting.
The electronics upgrade is complete but I still have a few extras on the way to add detail to the model. With the elmod board in I had no further issues with sluggish speed using a battery pack.
The model in action https://youtu.be/OVsq3kO9ytA
#2 Posted : 13 July 2016 13:19:26
Nice upgrade, are you going to do anything to the paint, weathering maybe?
#3 Posted : 13 July 2016 15:23:06
That's pretty cool! The sounds and start up are awesome.
I'm m also wondering if you're going to do anything with the paint?
#4 Posted : 13 July 2016 17:35:44
Looks and sounds good to me
kenjara
#5 Posted : 13 July 2016 18:06:32
Thanks guys.
I have taken some photos of a real one at tankfest this year so will look at giving it a spot of weathering.
Also have some speaker wire for the front winch, a flag for the antenna and some sandbags to fit to it.
I have been looking for some ww2 US satchels or something but not found anything yet.
#6 Posted : 13 July 2016 22:41:33
Very nice work indeed. I do agree with the others, a touch of weathering would make it even better....
#7 Posted : 22 July 2016 13:13:53
Nice looking model, great upgrades,
Ian
#8 Posted : 22 July 2016 19:32:45
Just caught up with this Kenjara and I have to say what a fabulous model! Love all of the working guns, lights and sounds, really brings it to life and great work on converting it with the upgrade - very well done!!
Kev
