hull plank colour Options
IAN
#1 Posted : 10 November 2010 14:20:58
Hi every one..
I have just re- visited the DVD that came with the first magazine, to see if I can gain any close up pictures of the lower section on the hull build and noticed that the planks are a darker colour to the upper section.
As I would like to leave my build in the natural wood look, is it better to stain the planks before assembly ?
Ian
Ian
Builds in progress: E-type, HMS Victory, HMS Endeavour, HMS Soverein of the Seas
Wish list: Bentley Blower
http://forum.model-space...spx?g=posts&m=30439
http://mxpublishing.co.uk/engine/shop/product/9781780920184/Hunt+for+the+Blower+Bentley
#2 Posted : 10 November 2010 14:44:24
Once the planking is in place it will need sanding which in turn will remove the stain, and glue stength may also be hindered.
Lonestar Spirit
#3 Posted : 11 November 2010 09:23:22
Which should make it a pain in the rear end to stain, one slip and the stain will bleed into adjoining timbers! then you have to consider if the glue or filla you use is stain-able, this could cause all sorts of problems.
Ship Builds on the go
Maldbuild
#4 Posted : 11 November 2010 14:55:22
Question for Tomick , Could you advise , I am second planking the hull , What type of Planking ETC Walnut ,Lime , would you use for the top of Victory and what for the Bottom half of Victory .
MaldBigGrin
#5 Posted : 11 November 2010 15:52:54
Veneer strips for both - Walnut or Cherry bottom and the Lime top, down to personal choice.
Maldbuild
#6 Posted : 12 November 2010 01:06:31
Thanks for you reply Tomick. your help and advice is much appreciated.
Mald
BigGrin BigGrin
This page was generated in 0.092 seconds.
