Pull starter Options
Jors
#1 Posted : 30 June 2016 16:05:39
Rank: Amateur level 2
Hi
I broke my pullstarter's rope can I fix it?
kenjara
#2 Posted : 30 June 2016 17:25:52
You should be able to get some similar size cord to replace it. You will need to make sure you get the knot right when fitting the new cord into the pull starter casing.
Is the rest of the mechanism intact? If you have not taken the pull starter off yet make sure you do it carefully so that the coil stays in.
Plenty of potential replacement cords come up if you Google pull starter cord.
This page was generated in 0.124 seconds.
