difference in stern build Options
IAN
#1 Posted : 03 November 2010 16:00:21
Hi , Tomick and every one....
I have noticed a difference in the stern build from magazine to on line.
I have attached two pictures one shows a three plank gap at the rear ( in magazine ) and the on line build shows only one.
Is it important on which one is followed?
Ian
IAN attached the following image(s):
Ian
Builds in progress: E-type, HMS Victory, HMS Endeavour, HMS Soverein of the Seas
Wish list: Bentley Blower
http://forum.model-space...spx?g=posts&m=30439
http://mxpublishing.co.uk/engine/shop/product/9781780920184/Hunt+for+the+Blower+Bentley
willie
#2 Posted : 03 November 2010 16:30:02
count the port holes in the two pictures you will see where you are confused there is three more aft
Dontshootme
#3 Posted : 03 November 2010 19:29:11
Willie,I think you are mis reading this,if you look at the 2 pics,the online one shows a 1 plank vertical & then a slope above stern gallery,the magazine shows a 3 plank vertical then the slope.
I'm afraid I can't help you Ian as I am yet to start the planking but i'm sure someone will be able to help you.
willie
#4 Posted : 03 November 2010 19:47:09
well mine is about 11/2 planks there i go buy the cut out template at that point
benny
#5 Posted : 03 November 2010 19:59:46
we have spotted a couple of errors with the mag build before..i have already planked the upper half of my build and mine is the same as tomicks...cheers paul
cheers benny
#6 Posted : 03 November 2010 21:14:57
Ian, when you apply the stern template, you should find that the step before it goes off at an angle is approx the width of one plank as per my photo, so the advice is to follow the line of the template rather than what you see in planks.
IAN
#7 Posted : 04 November 2010 14:46:28
To..
Tomick - dontshootme - Benny - Willie - .
Many thanks for your help and input.
Ian
Ian
benny
#8 Posted : 04 November 2010 18:32:51
anytime ian just ask...paul
cheers benny
willie
#9 Posted : 04 November 2010 19:22:16
that what the form for even if we do get a bit muddle
This page was generated in 0.122 seconds.
