15 Pages «<34567>»
HMS SURPRISE Build Log by Barry Options
#81 Posted : 24 June 2016 23:11:55
Very nice work Barry. Those lights look great.
BarryM
#82 Posted : 25 June 2016 21:41:06
Thanks Chris, wouldn't be doing this if it weren't for the masters like yourself..
The inner planking and gun port lining are taking a little longer than I expected, going into the third day already and not even half way down the port side yet with still a lot of touching up to do...Keeps me off the streets though.
Barry
BarryM attached the following image(s):
There's no time like the present.....
#83 Posted : 25 June 2016 23:39:48
Building these ships Barry is never a race and the fact you're taking your time with it is really paying dividends, she's looking fab.... Very well done....
#84 Posted : 26 June 2016 15:22:19
Hi Barry
I've just caught up with your build of this and must say you are doing a sterling job with her, I'm really loving what you have done with the lanterns!!
I was also inspired by some of the masters here to tackle a ship build, I started the Santisima Trinidad, however at the moment it's still sat in its jig waiting for the second layer of planking to be done. I must get back to her sometime but just so much else going on.
Keep up the great work and keep the pictures coming
BarryM
#85 Posted : 26 June 2016 17:04:10
Hi Dave,
Thanks for your comments, I should have started this years ago, the old eyeballs are not what they used to be..I finish a part and say to myself "that looks o/k" then revisit it a bit later Hmmmmm a bit more of this a bit more of that. The digits on the front paws not fairing much better either, after a couple of hours they start to resemble an old gnarled tree...all in good fun though..haven't had as much fun since I left Girl Guides or was that the Scouts.
Barry
BarryM
#86 Posted : 28 June 2016 14:11:48
I started cutting out the port-side Gun Ports around the 18th, now the 28th June, had no idea it would take that amount of time after lining them and fitting the inner planking...Happy with the results so far though, now onto the starboard side..here's a few pics..
Barry
BarryM
#87 Posted : 30 June 2016 14:33:59
TIP..when cutting out the Gun Ports it's much easier to cut a "V" section than trying to cut through the Basswood when cutting the vertical sides across the grain, a bit like cutting down a tree..
Barry
BarryM
#88 Posted : 04 July 2016 21:16:38
Managed to get the Starboard gun ports finished today together with the lanterns..was much easier and quicker than the port side, just got to add a couple of planks onto the inside of the bow section and then a couple more on the stern and then wait for the hull planking to arrive...
Barry
#89 Posted : 04 July 2016 22:11:35
Hi Barry.
Very nice clean build. look forward to seeing more.
Ian
#90 Posted : 04 July 2016 22:33:26
Lovely work Barry, excellent job on those gun ports....
johncal
#91 Posted : 05 July 2016 17:49:51
I see you flattened down the front of the bow, looks good. Gun ports are coming along nicely as well. Of course I like the lanterns. I like the .22 shells as housings, very ingenious. They will add a lot for the display. I can't tell from the pics, did you use the flickering candle LED's?
BarryM
#92 Posted : 05 July 2016 20:17:01
Thanks Gents for your words of inspiration...
Glad I'm not building the Victory, don't think I could manage all those gun ports...
John..I had some yellow standard LED's in my toy box and started playing with those and the .22 cases, they looked o/k so I bought a few more, never thought about flickering LED's, great idea...too late now though.
By the way John, what camera are you using your pics are awesome?
Added a little more planking on the inside to bring it up to the correct level..
Barry
johncal
#93 Posted : 05 July 2016 20:50:33
Barry
Just using my iPhone 6 huge. I'll break out the Canon 70D when it's time.
BarryM
#94 Posted : 07 July 2016 17:38:57
The inner hull planking is complete extended up to the bottom of the top deck and the inner bit up at the front....
Waiting on the Hull Planking should be here in a couple of weeks, mean time to keep myself busy I've decided to copper plate the hull after looking at many other builds. I'm going to use self adhesive copper foil after looking at a few "how to do it" pages, couldn't find any 8mm strip down here so had to buy 50mm wide and perform some surgery on it.
First made a jig with 1mm holes drilled in it strategic places..
Next roll out the copper foil and cut off a piece..
Attach the foil to the jig with a couple of bits of masking tape with the peel off inner facing the jig..
Using a .7mm marker mark the holes onto the foil backing..
Score the copper side to represent the individual tiles and then cut the strips..
Use a pounce wheel on the edges and a small punch to mark the edges..and presto..
Going to need considerably more, but time on my hands right now..
Barry
#95 Posted : 07 July 2016 17:45:18
Very nicely done with the copper tiles looking brilliant Barry
#96 Posted : 07 July 2016 21:36:10
Hi Barry.
copper tilling looks great. look forward to seeing on your build.
Ian
#97 Posted : 07 July 2016 22:33:22
Hi Barry,
Great to see copper tiles. I wasn't confident enough to do them on mine. Hats of to you for going that route.
BarryM
#98 Posted : 08 July 2016 08:19:42
Thank you for the encouragement gents, couldn't resist the copper thing looks really good on some of the builds I've seen but still some way to go before I attempt it. The hull planking...I've read, re read, looked at as many pics as I can find and still apprehensive, I've planked a few RC planes in the past with balsa but I think that was a piece of cake compared to this..keep you posted when I get started.
Barry
BarryM
#99 Posted : 10 July 2016 19:35:28
Got around to a couple of those little jobs that needed doing...
Stern planking..
Wiring studs..
And trim the lower decking at the stern..
Barry
johncal
#100 Posted : 11 July 2016 00:24:02
Fun drilling down into that keel, isn't it?
15 Pages «<34567>»
This page was generated in 0.291 seconds.
