2 Pages <12
Not working Options
ncall1976
#21 Posted : 24 June 2016 11:34:30
Started to print and working fine, then I get this
11:31:48.295 : : Extruder switched off. MINTEMP triggered !
11:31:48.315 : Error:Printer stopped due to errors. Fix the error and use M999 to restart. (Temperature is reset. Set it after restarting)
can't restart now. have looke at repetier forum for answers, but confusing isn't the word.
michu
#22 Posted : 24 June 2016 12:51:18
This error can happen when the electronics lose the signal from the thermistor. This might happen due to bad connection. Switch the printer off, disconnect power and USB cables, then try reseating your thermistor connection at the board header.
Happy building :-)
ncall1976
#23 Posted : 24 June 2016 14:04:07
tried that, no go.
think I might have a faulty board, usb connector takes 3-4 attempts before green light stays on.
then it goes off as soon as you plug power in.
#24 Posted : 24 June 2016 16:45:11
Possibly the top or bottom circuit board has been cracked when joined together. It's a delicate process and the parts a tight to fit together which can be cracked by forcing them.
Request replacement by stating the Stage/Issue number for each via c/s
ncall1976
#25 Posted : 25 June 2016 22:40:03
found the problem, the sensor has melted the wire
2 Pages <12
This page was generated in 0.277 seconds.
