HMS hannibal 1/96 scale majestic class battle ship Options
#1 Posted : 23 June 2016 13:50:44
PACK 1 OF 1
Hi all get me build diary up an running on this one.first steps are to sand the top of the hull down to its correct level, then sand seam off bottom.then it's add 3 stiffeners to Hull bottom.drill out holes in Hull to take temporary brass rods, which are there to aid putting the deck support strips around inside edge of Hull. First 2 glued in.that's it for now.cheers mick.
#2 Posted : 23 June 2016 17:15:45
Hi Mick,
Looks like you`re off to a good start. WTG
I`ve got some of those pegs for clamps, they are real good as they have soft pads where they clamp the parts together, but it looks like you may cause a national shortage. LOL
Keep up the good work
#3 Posted : 23 June 2016 19:04:51
Nice start Mick
#4 Posted : 23 June 2016 21:08:33
Nice start Mick.
Look forward to seeing your progress.
Ian
#5 Posted : 23 June 2016 22:51:54
Great to see you up and running with this one Mick. Great start and I for one will be following all the way....
#6 Posted : 07 July 2016 12:57:19
Hi thanks to all that left comments, much appreciated. Anyhow between decorating flat.and sorting new model space out.I managed to get bit more done.glued the A frames in to support prop shafts.finished off deck supports.cut deck out.it fits where it touches.p38 will sort that out.cut the rectangular hole out in main superstructure. And made start on the bits in well area.the one with few fittings on is generator room.which I drilled holes through skylights.as intend to light up the ship.others are funnel housing.and to small ventilation intakes. The fittings do require a lot of cleanup.don't know how gonna model the big grey lump amidships on the drawing yet (big grin.ain't kitty cats help full eh.
#7 Posted : 07 July 2016 18:18:23
Hi mick
Looking good and starting to take shape now
#8 Posted : 07 July 2016 21:44:33
Hi Mick.
taking shape nicely. the PE looks good.
Ian
#9 Posted : 07 July 2016 22:49:40
Looking good Mick and progressing very nicely..... Nicely done....
#10 Posted : 13 September 2016 18:01:45
Hi Mick, just wondering how your getting on with this build?
#11 Posted : 13 September 2016 18:02:41
He seems to have built a cat!LOL
#12 Posted : 13 September 2016 18:22:35
Hi MrT I have put this one up for while till I have completed my railway gun. Sorry for the delay but this be my next project. Cheers mick.
#13 Posted : 13 September 2016 18:30:18
Cheers Mick, look forward to you being back on it and good lok wit the rail gun, looks impressive Cool
#14 Posted : 13 September 2016 20:26:02
BigGrin Have fun with the Rail gun MickCool
This page was generated in 0.160 seconds.
