one for Tomick Options
wallace
#1 Posted : 01 November 2010 17:30:20
Hi Tomick
In layer eleven the plank that goes round the bow at bow former 11a is just about level with the top of the bow former but when it reaches the centre bow former 8 it is a couple of mil under the top, i have not yet glued this plank in place and would be grateful if you could tell me what to do about it.
Thanks
#2 Posted : 01 November 2010 17:50:31
You need to follow 7B on page 11 of issue 26 and 8B on page 13, basically you need to add another layer at the bow, but before you lay layer 11 at the bow check that there is enough projecting frame to secure layer 12, if not you'll need to taper the layer 11 plank to around 3mm from about frame 13 to the bow end.
wallace
#3 Posted : 01 November 2010 18:08:47
Thanks Tom, i had read that part in the mag but because it was level at 11a was not sure.
much appreciated.
This page was generated in 0.110 seconds.
