Joined: 22/01/2016 Posts: 3 Points: 9 Location: Bristol, PA USA
My cylinder and piston on my RB-7 seem to fit too tight at TDC but I am new to Nitro Engines so I'm not sure. With the crank, sleeve, piston and connecting rod all installed I cannot turn the engine through TDC with out the piston lifting the sleeve out of the block. And if I install the cylinder head it stops around 1/16" BTDC. Is this normal? Does it need to be that tight for good compression? Will the pull starter overcome this stiff spot? Anybody? I am baffled and don't want to hone the sleeve out any if this is how it should be.
hi Aldove, welcome to the forum.I am forum support for USa so let me know if I can help in any way
