planking thickness Options
benny
#1 Posted : 29 October 2010 18:43:37
as a few of us are second planking to be satisfied with our build is there a maximum thickness of the final planks..this model is supposed to be single planked but i am second planking with 0.5mm planks.. so do we need to sand the first planks down to 1mm thick to allow for the 0.5 mm planks to go on top, does that half mil really matter?..thanks paul
cheers benny
captainalan
#2 Posted : 29 October 2010 20:51:52
benny if your putting 0.5mm venner on top, then you only need to sand down 0.5 mm
benny
#3 Posted : 29 October 2010 21:02:12
hi alan,so if thats the case the people who are single planking cant sand at all..what i am asking is is there a thickness we are aiming for..if we av 2mm planks do we have a 0.5mm sanding tolerance
cheers benny
#4 Posted : 29 October 2010 21:57:26
benny i'll try to answer that question if I may,al designed for single planking,assuming you know what your doing,they probily allowed 1/2mm for sanding,so you can sand 1mm. or .5mm, for your .5mm second layer..5mm is not going to make any difference.whoops typo there now corrected.
benny
#5 Posted : 29 October 2010 21:58:35
cheers karl exactly what i was after..paul
cheers benny
Swampy
#6 Posted : 29 October 2010 22:42:01
Rank: Amateur Level 1
Location: Kent,birthplace of HMS Victory and the second HMS Temeraire
.05mm That is 1/20th of a millimetre-now that is thin planking!!
axle396
#7 Posted : 30 October 2010 02:01:03
LOL LOL LOL LOL
Jimmy L.
current builds : Lancaster 1/32 (Hachette)
Revell USS Kearsarge
Titanic Lifeboat
I started off with nothing and I've still got most of it left.
This page was generated in 0.105 seconds.
