Joined: 05/03/2015 Posts: 561 Points: 1,713 Location: South Carolina
Now that is some Falcony goodness at it's best right there my friend! Nicely done!
This is going to look amazing when complete and something to be very proud of!
I love watching these Falcon builds and the work going into them, and this is no exception! Fantastic work!!
Many thanks for your kind words, your encouragement is really appreciated. Mark Regards Markwarren (Mark) Admin
I haven’t done much over the last 3 weeks, other than started with the engine recesses, waiting several days for each paint part to dry before continuing. Made up for it this weekend, screwed all the top panels in, except the cone section, and finished the damages hull section from light bleed. I have also finished the engine recesses, maybe a little more tweak once I’ve fitted them.
Cheers for looking MarkMarkwarren attached the following image(s): Regards Markwarren (Mark) Admin
 Rank: Pro  Groups: Registered
Joined: 04/07/2015 Posts: 99 Points: 309 Location: north wales
As always mark... Simply jaw dropping work youve done there ....
Joined: 13/05/2016 Posts: 130 Points: 386 Location: Murrieta, CA (USA)
Mark waiting to see your latest I saw were you posted that you received up to issue 72 (I think it said). I received almost all of issues up to issue 68 in the batch buy that I did they failed to ship months 6, 7, 9 and 14 so there are 16 missing issue for some reason month 7 is on back order so I will be waiting a while for it. They shipped the other issues, so I am waiting for those. The unfortunate thing is I just received my self assembly 3D printer for a Kickstarter that I funded, so I need to built that as well along with the green house that I am building for my wife. So I have a pretty busy schedule of things to do. I have most of the metal frame assembled and I am going to spray it flat black then I am going to paint all of the skin with the Tamiya Insignia White and begin the real painting after that. Best wishes on your build. Bill Make things as simple as possible but not simpler... - Albert Einstein
Looking good so far my friend! Can't wait to see more!
Joined: 06/08/2015 Posts: 276 Points: 817 Location: Monrovia, Ca
Some very nice work there, Mark. You are definitely setting the bar high for the rest of us. Stephen Current Builds: HMS Sovereign of the Seas /// Lamborghini Countach /// Eaglemoss BTTF DeLorean
Finished Builds: Millennium Falcon
Whilst waiting for the next batch to arrive, I have been painting all the detail piping parts, which has taken a few weeks, ready to apply to the hull sections and then finally add fine detail to them. I have nearly finished the antenna, will post pics later when finished, but here are a few pictures for now, where I have put some pipework to the hull section. Thanks for looking. Mark
Wow... Looks great mark... Wish i had your patience to go to that level of detailing... It really does look superb ...once again you have raised the bar !!!!!
So, whilst still waiting for the next batch, I’m building the hold pit and rear room in the hold area, although I have lots of little bits to do. As stated in my last post, I’ve now posted some pictures of the antenna array which I’ve now finished, some close up shots as well as what it looks like on the hull. Lots of fine detail still to do, but it gives some idea on how it all coming together. Thanks for looking
Thanks MarkMarkwarren attached the following image(s): Regards Markwarren (Mark) Admin
As always Mark looking good. Markwarren wrote:So, whilst still waiting for the next batch, I’m building the hold pit and rear room in the hold area, although I have lots of little bits to do. As stated in my last post, I’ve now posted some pictures of the antenna array which I’ve now finished, some close up shots as well as what it looks like on the hull. Lots of fine detail still to do, but it gives some idea on how it all coming together. Thanks for looking
Thanks Mark Make things as simple as possible but not simpler... - Albert Einstein
Joined: 09/06/2015 Posts: 76 Points: 228 Location: Lancaster, CA
Great work.. Not an overkill. Tamiya 1/32 P-51D, Revell 1/32 Bf 109G-6 x2 1/32 P-51B, 1/32 Trumpeter Bf109K-4, 1/32 Hasegawa Bf 109E, Testors 1/32 F-117, RMF 1/35 Tiger 1
Joined: 09/07/2016 Posts: 59 Points: 181 Location: Biloxi, MS
I'm thinking that I like the top more than the bottom. Looks great.
Many thanks for all the kind comments, getting quite excited now its all coming together, although still loads to do. I left out a picture from my last post with the antenna in place. So here goes.
Keep up all the good work guys.Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
Love your paintwork Mark, looks great!!
Thank you Dave Regards Markwarren (Mark) Admin
Mark... I really love what you did with the blaster marks behind the Radar dish. Absolutely spot on bro! BRAVO!
Many thanks LrdSatyr8 Started on the mandible this weekend, I’ve done a couple of the engine recesses, still some more to do on these, with varnish and some final fine detail. A lot of prep work been done, so it will be sometime before its finished.
Cheers MarkMarkwarren attached the following image(s): Regards Markwarren (Mark) Admin
Guest (5)
