 Rank: Pro Groups: Registered
Joined: 08/02/2015 Posts: 426 Points: 1,259 Location: Louisiana
Hi fellows would anyone know if I need to make slots on the lower deck beams for deck 7A I know I needs to it the forward deck beams 7b but it doesn't say anything in the instructions for the back ones or is it optional Ronald
Yes, just at the rear. Have a look here from about 10 minutes on. Fitting the deck beams
thanks I did view the youtube segment of the deck build but it only shows the front not the back Ronald
Hi Ronald. You nerd to make shallow saw cuts in the aft beam to bend it to shape. The same as to fit the bow beams. Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
thanks Ian that's what I thought but wasn't sure but the instructions doesn't show it again thanks Ronald
The narrator explains it at 10:48.
No problem Ronald. The saw cuts need to be on the transom end of the beam to get the bend to the stern. Ian. Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
the transom end that's on the inside of each beam right
Hi Ronald. The transom end is the stern of the ship. Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
