lower deck support beams for the deck 7a Options
ronald305
#1 Posted : 11 June 2016 14:41:12
Hi fellows
would anyone know if I need to make slots on the lower deck beams for deck 7A
I know I needs to it the forward deck beams 7b but it doesn't say anything in the instructions for the back ones or is it optional
Ronald
z8000783
#2 Posted : 11 June 2016 14:57:29
Groups: Unapproved
Yes, just at the rear.
Have a look here from about 10 minutes on.
Fitting the deck beams
ronald305
#3 Posted : 11 June 2016 15:14:27
thanks
I did view the youtube segment of the deck build but it only shows the front not the back
Ronald
#4 Posted : 11 June 2016 15:29:13
Hi Ronald.
You nerd to make shallow saw cuts in the aft beam to bend it to shape. The same as to fit the bow beams.
Ian
ronald305
#5 Posted : 11 June 2016 15:32:58
thanks Ian
that's what I thought but wasn't sure but the instructions doesn't show it
again thanks
Ronald
z8000783
#6 Posted : 11 June 2016 15:36:57
Groups: Unapproved
The narrator explains it at 10:48.
#7 Posted : 11 June 2016 16:54:33
No problem Ronald. The saw cuts need to be on the transom end of the beam to get the bend to the stern.
Ian.
ronald305
#8 Posted : 11 June 2016 17:22:11
the transom end that's on the inside of each beam right
#9 Posted : 11 June 2016 17:50:10
Hi Ronald.
The transom end is the stern of the ship.
Ian
ronald305
#10 Posted : 12 June 2016 18:52:35
ooh ok thanks Ian
Ronald
