13 Pages «<10111213>
HMS Guadeloupe (ex French Le Nisus), Brick de 24" by Jack.Aubrey - Scratch build - 1:48 Scale Options
jack.aubrey
#221 Posted : 08 June 2016 20:01:25
Wednesday, June 8, 2016
It is now +/- three weeks since I went back from Tuscany and it's just few days I began to think back to shipmodeling. Two days ago I reopened the Gokstad Viking shipyard, which, if everything runs well without glitchs, could be completed in a relatively reasonable time, that is, before I'll return to Tuscany in September.
On the other side, regarding the HMS Guadeloupe, everything is still in wait state. First I need to collect my thoughts because more than six months of inactivity made me forget many things. In Tuscany, I concentrated more on the history of this ship and, having discovered the existence of an original contemporary plan available at the National Maritime Museum in Greenwich, I intrigued to buy it.
Definitely a good purchase, which clarifies many aspects regarding the appearance of this ship, which also differs in rather important points from the French project: figurehead, breakwater, main piece of the knee of the head, quarter badges, shape of the taffarel, positioning of the shrouds. It's my intention to take pictures of these details, to illustrate in deep the differences, in future posts.
Meanwhile, thanks to the collaboration with another modeler who is building this same model (he decided to name it "Le Colibrì") it was started the realization of the ship carronades. A master of these parts was made. More in deep two of them: a) one for my friend who uses the original "Le Colibri" carronades, reproduced in detail in the ANCRE plans, b) while for my model, which was armed after his capture by the Royal Navy, the master was made using a English-barrel pattern, almost similar but not equal to the french one. Thanks to researches on the internet I found the design that I needed.
Finally, my friend found and contacted a company in Gazzada Schianno (VA) which set up the fusion process of the pieces needed starting from the masters. All this is the result of my friend work, I limited myself, due to my absence, to simply pick up the pieces and to pay the due amount, amount which will then be divided between us.
Below are some pictures of the guns barrels, both for my Guadeloupe than for Le Colibrì.
HMS Guadeloupe:
01 Brick%20de%2024%20Plans/20160607_161723_zpsfa9cor8w.jpg
02 Brick%20de%2024%20Plans/20160607_161634_zpsug8m4rsm.jpg
Le Colibrì:
03 Brick%20de%2024%20Plans/20160607_161816_zpsbi4lpneq.jpg
04 Brick%20de%2024%20Plans/20160607_161821_zpsujf95oug.jpg
Both barrels in the same image, left the English ones. .
05 Brick%20de%2024%20Plans/20160607_161925_zpsupznxpux.jpg
Cheers, Jack.
PS: The color of the metal, which in the pics seems almost golden, is strongly distorted by artificial light, in reality it's very similar to silver (the material used for casting is a pewter alloy, I don't remember the right name). Obviously, the pieces have to be treated to give them the classic "gun metal" color . .
jack.aubrey
#222 Posted : 13 June 2016 09:20:21
Sunday, June 12, 2016
I finally took a few pictures of the HMS Guadelupe plans I purchased at the Greenwich NMM.
The five images below proposed highlight the five areas that I have (so far) identified as main differences between this plan and the one provided by the ANCRE monograph of "Le Cygne".
But . . I forgot to take the same images of the ANCRE plans, so we'll have to wait I get pictures of them too. Now we can only visually introduce the five differences shown here below.
So please . . have some patience for a while.
1st difference at prow where no one knew until now how it was done: the figurehead. In addition, the bow shape is different, slimmer and slender.
01 Brick%20de%2024%20Plans/20160611_114237_zpsigmpluxt.jpg
2nd Difference: the side quarter badges are totally missed.
02 Brick%20de%2024%20Plans/20160611_114302_zpskjwrajos.jpg
3rd difference: the profile of the transom/taffarel is different from "Le Cygne", narrower and with square gunports.
03 Brick%20de%2024%20Plans/20160611_114415_zpsqajhnadd.jpg
4th and 5th difference: the shrouds positioning of foremast and mainmast are different than "Le Cygne"".
04 Brick%20de%2024%20Plans/20160611_114246_zpspkhdqmrq.jpg
05 Brick%20de%2024%20Plans/20160611_114252_zpsg8j2xzwa.jpg
But there are also other minor but still important differences.
As soon as I can spot pictures of the ANCRE plans you will probably understand better.
That all till now.
Regards, Jack.
jack.aubrey
#223 Posted : 30 August 2016 08:35:22
Tuesday, August 30th, 2016
Having recently finished another model (the Gokstad Viking Ship) I have resumed the shipyard of HMS Guadeloupe . . my long term project.
I needed some time to reorganize my mind about the tasks to be accomplished and I decided to complete the elements that I was working on before temporary closing the shipyard: the ship boats, launchs and lifeboats.
Now I'm workin' on the longboat, the larger of the three. Before closing the yard this was the situation:
01 Brick%20by%20JackAubrey/P1100393_zps7wuwc84s.jpg
So, I started to double the hull frames, as shown in the following picture . .
02 Brick%20by%20JackAubrey/20160827_105221_zpstw7zhvhn.jpg
03 Brick%20by%20JackAubrey/20160827_105229_zpswznoyasa.jpg
and then began to set up the internal fittings . .
04 Brick%20by%20JackAubrey/20160830_085054_zpslv6l2nvw.jpg
05 Brick%20by%20JackAubrey/20160830_085045_zpshibifvqk.jpg
06 Brick%20by%20JackAubrey/20160830_085103_zpsqxjwbq6x.jpg
After this step, I applied my usual wood oil on the internal sides, to hughlight the wood colour, last three images are shot after this task.
Regards, Jack.Aubrey.
#224 Posted : 30 August 2016 11:13:43
Good to see you back on this one Jack.
jack.aubrey
#225 Posted : 04 September 2016 17:28:17
Sunday, September 4th, 2016
I've been three days in the hospital for an invasive medical examination. So my modelling tasks had a stop for a while, but yesterday I resumed the ship boat and added some new elements . . . Here below some of them. Rgds, Jack.
01 Brick%20by%20JackAubrey/20160903_190438_zpsg1c4e7pk.jpg
02 Brick%20by%20JackAubrey/20160903_190355_zpslwju1qq1.jpg
#226 Posted : 04 September 2016 18:51:24
Hope you are feeling better Jack and you have made a lovely job on the ships boat
#227 Posted : 04 September 2016 21:05:27
Nice to see you back at Jack, hope you're not feeling too bad after your exam
#228 Posted : 04 September 2016 23:13:25
Doing a mighty fine job. I like what you have done with the ships boat.
Well done.
jack.aubrey
#229 Posted : 06 September 2016 11:03:43
Monday, September 5th, 2016
Another small step forward on the ship launch . .
01 Brick%20by%20JackAubrey/20160906_090708_zps4w8xzlnm.jpg
02 Brick%20by%20JackAubrey/20160906_090756_zpsumfeyeyw.jpg
03 Brick%20by%20JackAubrey/20160906_090714_zpstp7vxila.jpg
04 Brick%20by%20JackAubrey/20160906_090744_zps08topydh.jpg
05 Brick%20by%20JackAubrey/20160906_090657_zpsageocajs.jpg
PS: regarding my hospital stay, everything went well and, matter much more important, there was nothing wrong. Thanks to everybody.
Gibbo
#230 Posted : 06 September 2016 16:37:40
I've been looking forward to you starting this one up again Jack, craftsmanship as always.
Paul
jack.aubrey
#231 Posted : 12 September 2016 12:40:51
Monday, September 12th, 2016
A new step in adding details to the longboat . . it is a very interesting, amusing and relaxing task, provided your have a lot of patience . .
01 Brick%20by%20JackAubrey/20160912_122945_zpsqxbrqec1.jpg
02 Brick%20by%20JackAubrey/20160912_123156_zpswnwq1wru.jpg
03 Brick%20by%20JackAubrey/20160912_123209_zpsdnxjpyvp.jpg
04 Brick%20by%20JackAubrey/20160912_123124_zpspl7igkly.jpg
#232 Posted : 13 September 2016 07:14:13
Very nicely done Jack the boats fittings look brilliant
jack.aubrey
#233 Posted : 17 September 2016 11:16:09
Added the rudder and some other small details . . . now a coat of clear matt paint and then it's time to proceed with the second boat . .
01 Brick%20by%20JackAubrey/20160916_205406_zpslqmygcaw.jpg
02 Brick%20by%20JackAubrey/20160916_205713_zpsrj5hzvd6.jpg
03 Brick%20by%20JackAubrey/20160916_205348_zps4g1zac0d.jpg
#234 Posted : 17 September 2016 14:11:35
stunning work as usual.
jack.aubrey
#235 Posted : 31 August 2017 16:49:55
Important notice:
I'm trying to recover the images lost thanks to ... Photobucket (AngryAngryAngry). I've a lot of work to get the final goal, anyway be patient that I'm sure to be totally successful. It's only a matter of time.
Cheers, Jack.
#236 Posted : 31 August 2017 20:13:23
Good luck ThumpUp
#237 Posted : 31 August 2017 23:27:12
jack.aubrey wrote:
Important notice:
Cheers, Jack.
Hi Jack, you may find the second to last post here to be of some help in recovering your images. Hope it all works out for you....
http://forum.model-space...amp;m=253641#post253641
jack.aubrey
#238 Posted : 04 September 2017 10:40:25
Monday, September 4th, 2017
Important Notice
Today I successfully recovered all the images of this topic, so from now on all the images here published are well visible as before.
It was a hard work, but should be complete and reliable.
Thank you in advance for your patience. See you soon, Jack.Aubrey
#239 Posted : 04 September 2017 10:44:39
Great news JackThumpUp love watching your buildsBigGrin regards PhilCool
#240 Posted : 04 September 2017 12:47:00
Well done for getting this diary back together. I know from experience how much time it takes to recover and repost pictures into diaries. Crying
I look forward to seeing future updates.
Cool Cool Cool Cool
This page was generated in 0.248 seconds.
