21 Pages «<1213141516>»
John Passmore Options
#261 Posted : 31 May 2016 12:06:27
Hi John.
Looking a very nice clean build. Look forward to seeing your next inatalment.
Ian
nightwisher
#262 Posted : 31 May 2016 17:34:30
Nice progress on the bling. I also had trouble with a few pieces not fitting ,ended up just swapping them around.
Had a dream to understand
A single grain of sand
He gave birth to poetry
But one day will cease to be
#263 Posted : 31 May 2016 18:48:55
Awesome job John, all that bling looks fantastic. She must have been quite a site in the flesh
John Passmore
#264 Posted : 30 June 2016 13:03:24
tf64 wrote:
Hi John,
This is a perfect example of this great ship and the skills you have shown, thank you for posting and looking forward to you next update.
Trev.
Hi Trev
Thank you for the nice comment and encouraging words. Updating shortly.
JohnP
John Passmore
#265 Posted : 30 June 2016 13:06:42
magpie1832 wrote:
Very nice work John. Nice clean lines.
Well done.
Hi Chris
Thanks for the compliments. This months update following shortly.
JohnP
John Passmore
#266 Posted : 30 June 2016 13:09:51
Tomick wrote:
Well done John, looking great!
Thanks Mr T for the kind words of encouragement.
JohnP
John Passmore
#267 Posted : 30 June 2016 13:12:42
ian smith wrote:
Hi John.
Ian
Hi Ian
Thanks for looking in and the compliment. Next installment will follow in a minnit.
JohnP
John Passmore
#268 Posted : 30 June 2016 13:19:26
Hi Nightwisher
Thanks for looking in and the nice complement. Yeah - this little caper is harder than I initially thought but I'm getting used to it. I'm having a couple of months break from it next month but June progress is following shortly.
JohnP
John Passmore
#269 Posted : 30 June 2016 13:21:59
Hi Dave
Thanks for the nice words of commendation. June progress following.
JohnP
John Passmore
#270 Posted : 30 June 2016 14:01:56
Hi Everyone
June 2016 progress report AND photos herewith - I splashed out on a new el-cheapo camera...
Working through Issues 97 to 100 excluding cannons and fighting tops.
* Fitted chain wales, dead eyes and chains last month, so chains just needed anchoring to the hull now. The instruction of issue 100 item 13 seems a little ambiguous and my initial pin line was drawn in the wrong location. The following pics (14, 15 and 16), although not clear, seem to have the line drawn on the centreline of the upper black band. I found Mr Gandale's pictures on this topic, and as expected, confirmed the pin location. Thanks Alan.
The little brass pins are too thick to go into a chainlink with two adjoining links, so I used a fine sewing needle to select the correct link required as the anchor point, then cut the chain before pinning.
The foremast and mizzenmast chains posed no problems.
* First 12 cannons painted and fitted starboard side.
* Complete figurehead dry fitted.
* Second 12 cannons painted and fitted starboard side.
* Belaying pins and racks fitted.
That's all for the present, there will be no more progress now for a few months (perhaps November) as I'm off to UK for a well earned R&R...lol
Kind regards and happy building to All
JohnP
John Passmore attached the following image(s):
#271 Posted : 30 June 2016 14:49:53
Hi John.
Stunning looking build, well done.
Look forward to seeing your next update.
Ian
John Passmore
#272 Posted : 11 December 2016 13:46:45
Hi Everyone - I'm baaa-ck!BigGrin
Been busy with other things past 6 months so not a lot of progress to date...Blink - however - showing what I have done the past couple of weeks...BigGrin
I have all 135 issues now to hand.
Issues 104 and 104 refer;
* Made up some more fighting tops and ships launch cradle...Cool
* Completed all remaining cannons and blocks and tackle - mass production style...Cool. I didn't like the shiney silver wire on the blocks and so painted them all black after fitting to blocks. Very tedious but looks much better...Cool (The wire will not blacken in Krick).
Likewise I blackened all the eyelets to match...BigGrin
* Made up and installed the two bilge pumps...Cool
Kind regards and Seasons Greetings to All
JohnP
John_Passmore
#273 Posted : 12 August 2017 13:45:09
Hi Everyone
I haven't been able to log in to the forum since the beginning of the year as my account mysteriously disappeared...Blink Model Space IT finally got me going again...BigGrin
Following is my progress for the year so far.
Jan 2017
Main deck cannons rigged and fitted.
Feb/March
Secondary cannons rigged and fitted. Had a lot of trouble here, as I had made a lot of blocks and tackle in advance and found them too big (long) to allow the cannons to sit close enough to the porthole...Blushing, so had to disassemble them all and start again...Blink I also moved the eyelets further back on the gun carriage...Cool
April
Deck details fitted - ships boat, ships bell and some handrails/stanchions round the two openings in the deck gratings...Cool
May
Extracted all die cast decorations from all issues, the two gangway access doors, then painted and installed generally as directed...Cool Also fitted the steps up the side of the hull...Cool
I shall not add the curly decorations from issue 114 as I think the ship looks a bit busy already...Blink Likewise I shall not be painting the black surrounds of the stern gallery windows...Cool
June-August
Fabricated and fitted all the gun port hatches.
Assembled the three masts and bowsprit. Foremast is glued in but remainder are dry fitted only...Cool
August
All twenty foremast shrouds are fitted...Cool Bit tricky initially, but got easier as I became more adept at it. No pictures of them yet as my new el-cheapo camera is playing up already!...Blushing (maybe I should spend a few more dollars in this area)...Laugh
That's all for now as I'm off to France next week for a couple of months...BigGrin
Happy building to all
JohnP
John_Passmore attached the following image(s):
John_Passmore
#274 Posted : 12 August 2017 13:55:05
Hi all
I didn't get to finish what I was posting....got cut off...Blink
John_Passmore
#275 Posted : 13 August 2017 05:48:19
Hi Everyone
Got the el-cheapo going again so following are some pics of the foremast shrouds...BigGrin
JohnP
#276 Posted : 13 August 2017 10:11:20
John
That is a real lovely model you are building.
#277 Posted : 14 August 2017 07:04:48
Absolutely amazing build!
John Passmore
#278 Posted : 15 August 2017 03:54:57
birdaj2 wrote:
John
Hi Tony
Thanks for the nice compliment...BigGrin
JohnP
John Passmore
#279 Posted : 15 August 2017 03:57:20
Hi Walter
Thanks for the great compliment...BigGrin
Posting another picture in a minute...BigGrin
JohnP
John Passmore
#280 Posted : 15 August 2017 03:59:51
Hi all
Here's another couple of pictures with all the background clutter (mess?) covered up...Laugh
JohnP
This page was generated in 0.365 seconds.
