Top quality work Trev, looks amazing..... Very well done...
Andy, Thanks for your comments very much appreciated and good to hear for you. Regards. Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Dave, Thanks again, I must say that the tailplane did take a bit longer than thought mainly due to trimming down and, check and check again routing. Regards Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Darbyvet, Thanks for your comments, I think the secret is to file down the straight edge not the curve to get an obtainable result. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Michu, Again thank you for posting a reply to my build appreciated. Working on the pictures have now received the lighting set and thanks for your advice. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Jase, Good to hear from you and thank you for posting a comment. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Alan, Always good to hear from you, and again thanks for your valid thoughts. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Excellent work as always Trevor, It has been a pleasure watching this build.
Joined: 11/03/2010 Posts: 234 Points: 734 Location: Whelpley Hill, Chesham
Lovely job, looking really good. Alec Built: Bluenose, Arab Dhow, HMS Bounty, Hummer H1, D51, Spitfire,E type Jaguar. In Progress: HMS Victory, , Yamaha YZR-M1
Adapt, improvise, overcome.
Hi Trev, More plating expertise on the tail section. WTG Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Thanks Nem for taking a look, hope to have an update this weekend. Regards Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Alec, thank you for your comments, looking forward to your next update and seeing how you are getting on. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Hi Derek, thanks for having a look at the Spit build, metal plates can be tricky I think you gain skills by practise, and you also learn how to correct your own faults. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
UPDATE:SPITFIRE. 060716. REBUILD ENGINE COVER. ADD MORE METAL PLATES TO FUSELAGE. In building the front top engine cover for some reason I put to much pressure when screwing down the top plate which completely smashed the end section as in the first picture.  In this picture you can see were I have rebuilt this section now to add rib's and the metal cover plate.  In these picture you can see that I have moved along the fuselage towards the tailplane, this I have plated port and starboard.   Just a small update this time but more soon. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Looks great Trev. Are you going to paint it or leave it bare metal?
Hi Carl,this will be airbrushed but I am wondering what type of metal primer would be ideal to use that will stick on and not peel of after time ? any idea's. Thanks for looking, Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
I use acid etch primer for metal, but I would test it first on some scrap metal in case it has a lacquer coating. I would also degrease it.
Excellent Trev, she's looking terrific....
Hi Trev! As always i envy your skills and love your build! I have a question concerning the pinheads. They look quite big and i can`t see them on pics of the real thing. Do they stay or are they removed at some point of the building process? I guess they must be inserted because the plates won`t hold otherwise? Greetings, Walter
Hi Trev, I have similar question, I know from your previous pictures that you have used small screws and not pins, why is this? Im nowhere near this part of the build yet but very interested in your thoughts because I will be at some stage. Will adhesive not hold these plates without pinning? Regards, Alec Built: Bluenose, Arab Dhow, HMS Bounty, Hummer H1, D51, Spitfire,E type Jaguar. In Progress: HMS Victory, , Yamaha YZR-M1
