32 Pages «<2728293031>»
tf64 Spitfire Build Options
#561 Posted : 30 May 2016 23:25:42
Top quality work Trev, looks amazing..... Very well done...
#562 Posted : 31 May 2016 08:26:09
Andy,
Thanks for your comments very much appreciated and good to hear for you.
Regards.
Trev.
#563 Posted : 31 May 2016 08:30:33
Dave,
Thanks again, I must say that the tailplane did take a bit longer than thought mainly due to trimming down and, check and check again routing.
Trev
#564 Posted : 31 May 2016 08:35:03
Darbyvet,
Thanks for your comments, I think the secret is to file down the straight edge not the curve to get an obtainable result.
Trev.
#565 Posted : 31 May 2016 08:40:03
Michu,
Again thank you for posting a reply to my build appreciated.
Working on the pictures have now received the lighting set and thanks for your advice.
Trev.
#566 Posted : 31 May 2016 08:42:13
Jase,
Good to hear from you and thank you for posting a comment.
Trev.
#567 Posted : 31 May 2016 08:44:40
Alan,
Always good to hear from you, and again thanks for your valid thoughts.
Trev.
#568 Posted : 31 May 2016 13:22:02
Excellent work as always Trevor, It has been a pleasure watching this build.
alemo
#569 Posted : 31 May 2016 13:40:59
Lovely job, looking really good.
Alec
Adapt, improvise, overcome.
#570 Posted : 31 May 2016 19:57:57
Hi Trev,
More plating expertise on the tail section.
WTG
#571 Posted : 04 June 2016 10:12:58
Thanks Nem for taking a look, hope to have an update this weekend.
Trev
#572 Posted : 04 June 2016 10:15:28
Alec, thank you for your comments, looking forward to your next update and seeing how you are getting on.
Trev.
#573 Posted : 04 June 2016 10:26:08
Hi Derek, thanks for having a look at the Spit build, metal plates can be tricky I think you gain skills by practise, and you also learn how to correct your own faults.
Trev.
#574 Posted : 06 July 2016 20:51:18
UPDATE:SPITFIRE.
060716.
REBUILD ENGINE COVER.
ADD MORE METAL PLATES TO FUSELAGE.
In building the front top engine cover for some reason I put to much pressure when screwing down the top plate which completely smashed the end section as in the first picture.
In this picture you can see were I have rebuilt this section now to add rib's and the metal cover plate.
In these picture you can see that I have moved along the fuselage towards the tailplane, this I have plated port and starboard.
Just a small update this time but more soon.
Trev.
#575 Posted : 06 July 2016 20:57:48
Looks great Trev. Are you going to paint it or leave it bare metal?
#576 Posted : 06 July 2016 21:07:21
Hi Carl,this will be airbrushed but I am wondering what type of metal primer would be ideal to use that will stick on and not peel of after time ? any idea's.
Thanks for looking,
Trev.
#577 Posted : 06 July 2016 22:01:28
I use acid etch primer for metal, but I would test it first on some scrap metal in case it has a lacquer coating. I would also degrease it.
#578 Posted : 06 July 2016 22:54:00
Excellent Trev, she's looking terrific....
#579 Posted : 07 July 2016 10:42:40
Hi Trev!
As always i envy your skills and love your build!
I have a question concerning the pinheads. They look quite big and i can`t see them on pics of the real thing.
Do they stay or are they removed at some point of the building process?
I guess they must be inserted because the plates won`t hold otherwise?
alemo
#580 Posted : 07 July 2016 11:22:20
Hi Trev,
I have similar question, I know from your previous pictures that you have used small screws and not pins, why is this? Im nowhere near this part of the build yet but very interested in your thoughts because I will be at some stage.
Will adhesive not hold these plates without pinning?
Regards, Alec
