Joined: 26/05/2014 Posts: 206 Points: 621 Location: Swellendam, RSA
Hi all, I have also been missing in action, being on leave and going down to the Breede River etc. Got issues 83 - 86 about 2 weeks back and only put them together on Sunday. Found a major problem with my radio stuff. The steering servo seems to be dead, if I plug it in the receiver goes dead. If I try other servos then the throttle response slows down. It seems that I have a dud receiver and servo. I will possibly change the radio after doing some more checks. I did start the engine and it sounds good, much quieter than my buggy. It's not the fall that kills you, it's the sudden stop
Building: Bismark, 2.5m wingspan glider
 Rank: Semi-Pro Level 1  Groups: Registered
Joined: 27/05/2015 Posts: 70 Points: 206 Location: South Africa
AndreZS1AZ wrote:Hi all, I have also been missing in action, being on leave and going down to the Breede River etc. Got issues 83 - 86 about 2 weeks back and only put them together on Sunday. Found a major problem with my radio stuff. The steering servo seems to be dead, if I plug it in the receiver goes dead. If I try other servos then the throttle response slows down. It seems that I have a dud receiver and servo. I will possibly change the radio after doing some more checks. I did start the engine and it sounds good, much quieter than my buggy. I tested my servos at least they working, you must try contact them to send you another one. Sounds like they don't do a proper quality check before sending parts out. I back ordered a issue at CNA a few weeks back, still haven't received it! Seems like the back order system is not controlled properly. I am even struggling with my Ferrari collection... I hope CNA receives the extra issues!!!! If everything seems under control, you're not going fast enough. RSA Building RB7
 Rank: Amateur Level 1   Groups: Registered
Joined: 20/05/2014 Posts: 33 Points: 105 Location: Pieternaritzburg, RSA
Hi All After nearly liquidating my business I've made a comeback and I'm glad to say I am continuing my RB7 build, have to start on issue 26 but at least I'm back. Any major concerns or issues regarding future builds/issues I need to be aware about? Have a great day. Life is precious...waste it wisely!
Nice to see you back with us, look forward to seeing the progress you make.... Regards Alan
Welcome back sparrowtwin, and if you follow instructions there should be no hassles with assembling the car. I did test the radio system when I first received it but it seems to have gotten a bug in the mean time. Jacklin said that they will replace it and I must send it back. It will cost me R275 for a courier to deliver the parts back to them because of the postal strike again. Of course I must strip the car to get the servo out but never mind, will get it done over the weekend. The engine starts well and was a bit rich of course for the break in. Just ran a bit of fuel through it and it sounds good. So, there you have it. It's not the fall that kills you, it's the sudden stop
Any one know how to repair a pull starter? See the spring hooked out. I have being waiting for a few weeks for a back order of my issues from CNA. So the build has not being happening. If everything seems under control, you're not going fast enough. RSA Building RB7
Joined: 16/05/2016 Posts: 1 Points: 3 Location: Pretoria
hi guys
Just received issue 90-94 do you guys know if we will still be receiving the optional 15 issue after issue 100?
carrim247 wrote:hi guys
Are you getting your books from CNA or through the post? I am by CNA and currently having issues with backorders by them! I am missing 3 issues which just dont come! If everything seems under control, you're not going fast enough. RSA Building RB7
Joined: 11/08/2014 Posts: 41 Points: 126 Location: Benoni, South Africa
hi
going to collect issue 100 tomorrow at CNA if 101 is there will let you guys know, the lady at CNA said she would let me know
Jors wrote:hi
going to collect issue 100 tomorrow at CNA if 101 is there will let you guys know, the lady at CNA said she would let me know Goodluck! The cna here said no! If everything seems under control, you're not going fast enough. RSA Building RB7
I received the remote and issue 17 earlier this week. Sent the damaged stuff back via courier so that they cannot say that they did not receive them. I will test the new stuff and then put the car back together and do the run in story using my own fuel mix. After that I will have to go commercial fuel because I have run out of fuel supplies. I am now running my buggy on 20% Beetle Juice from Speed Models in Tyger Valley area. My daughter brought me 8L, so that is a lot of car running. Enjoy Cheers and Beers It's not the fall that kills you, it's the sudden stop
update
I am getting the extra issues from my CNA in Kempton park jippeeee
So I just had about enough with regards to CNA & my back orders, wrote a review on hello peter. Hope that works, Every week i get there they don't have my issues. Otherwise I have being stuck with the build, fitted the racing body on. How does your cars look? Posting photos? If everything seems under control, you're not going fast enough. RSA Building RB7
Well, there you have it. That is one of the reasons that I went the subscription route. Been there, done it and have the T-shirt. Ok, the only thing that messed up the subscriber's was the postal strike. I have had some problems, but they were soon sorted out, got my new radio and issue 17 replacement, so no complaints from this side except some issues with the build. There is so much play on the bearings going into the wheels, steering slop, play on the ball joints, etc. For something costing so much money, I expected better from Kyosho. My buggy from Hobby King has much less slop on the vehicle. I will carry on with the build because I am nearly finished, but never again. It's not the fall that kills you, it's the sudden stop
Hi
I cant find the blue paint anywhere , do you guys have the same problem?
Jors wrote:Hi
I cant find the blue paint anywhere , do you guys have the same problem? Found this on the build forum: Tamiya PS-59 dark metallic blue Tamiya PS-19 camel yellow Tamiya PS-1 white or PS-5 black (backing coat) depending on the blue chosen. PS- 58 pearl clear (option) Tamiya TS-14 gloss black Tamiya TS-29 semi-gloss black TS-30 Silver (or X-11) Tamiya plastic primer - (for use with the TS paint) Check the link out, seems like they can help you http://www.jeffreystein.co.za/
Joined: 22/06/2014 Posts: 3 Points: 9 Location: Howick, KwaZulu Natal
Hi guys, I finally subscribed, I'm really excited to get cracking on it, it's my first project like this, how long did it take from date of subscription until you got your first few issues?
Finally getting my outstanding books, seems hellopeter helped. within 5 days or so they delivered the back orders! If everything seems under control, you're not going fast enough. RSA Building RB7
bpboshoff wrote:Hi guys, I finally subscribed, I'm really excited to get cracking on it, it's my first project like this, how long did it take from date of subscription until you got your first few issues? Not sure how long it took for the guys to get the first issues, will take about 2 years to complete (Give or take) Have fun with the build, its a lekker project! If everything seems under control, you're not going fast enough. RSA Building RB7
Anyone not receive issue 100? Due to not having a barcode. If everything seems under control, you're not going fast enough. RSA Building RB7
