Stage 72 Options
TomAv0
#1 Posted : 29 May 2016 10:55:30
Hi guys need some help
The suspension struts,the position of the top of the struts are not very clear and i dont want to glue them in the wrong position any advice how too position them correctly
cheers
Tom
#2 Posted : 29 May 2016 15:02:18
If you are unsure of the correct angle, you can leave the gluing until Stage 89 of Pack 23, where you can then set the joint to the perfect angle in conjunction with fitting the wheel fairings.
TomAv0
#3 Posted : 29 May 2016 21:13:33
cheers
think i will do that
