Model Airways Albatros D.Va -1917 Options
#1 Posted : 29 May 2016 20:06:01
Hi All
This is a kit from the Modelexpo stable and is at 1/16 scale with a wingspan of 22.5 inches I also have the Camel kit by this company but it has already had a build and review on the forum.
The kit comes in a sturdy blue cardboard box with a picture of the finished aircraft on its front and proclaiming it as 'The Red Barron's Forgotten Fighter' and that 59 of his Victory's were accomplished in this aircraft. On opening the box things look a little sparce content wise, a comprehensive instruction book and parts sheet along with 5 full size plan sheets. A large clear plastic box is next containing 7 very full bags of metal parts and other goody's, under this is the laser cut wing ribs sheet along with the fuselage formers and the propeller blanks, next is a large bundle of strip wood and next to that various metal rod and tubing. Right at the bottom is the laser cut fuselage jig parts.
All the wood parts in the kit are top quality along with the metal parts although the castings will need some work to bring them up to scratch.The plans and instructions are very detailed and take you through each stage of construction with plenty of diagrams of the part being worked on. All in all a nice little kit that should produce a very detailed model. One to recommend I think.
#2 Posted : 29 May 2016 20:32:59
I have this kit too Andy.Looking forward to seeing you build it.My recommendation from building a few Model Airways kits is to do an inventory because it takes them a while to get you replacement parts.They are very good at replacing parts, just not that quick
#3 Posted : 29 May 2016 22:33:12
Hi Andy.
Look forward to seeing this one come together.
Ian.
#4 Posted : 30 May 2016 10:54:17
#5 Posted : 30 May 2016 12:56:05
Hi Andy.look forward to this one, as would like to have a cracking at one meself, one day. So will be following with interest. Cheers mick.
michu
#6 Posted : 30 May 2016 15:42:49
I'll be following this one, I have two Model Expo kits myself - the Curtis "Jenny" and an Allerton pumper.
Both seem like a lot of work but should build into impressive models.
Happy building :-)
#7 Posted : 30 May 2016 16:11:59
Hi everyone thanks for looking in and your comments @ Michu the pumper looks like a nice kit too.
GilShapley
#8 Posted : 30 May 2016 19:40:49
Hi Andy
I built the Camel from Model Expo and I would agree to check the parts list although I will say that I had no problems with Model Expo supplying/replacing parts
An interesting build, the only major change I made was to construct my own propeller as I did not like the ply cut-outs provided. But I did use them as templates for my "home made" version.
I will watch you build with interest and who knows my Camel may soon stand next to an Albertros on the shelf
Gil
Current Build:-
#9 Posted : 30 May 2016 20:09:37
Hi Gil
I remember your Camel build and its why I bought the camel kit aswell. From a general look at the kit all the parts seem to be there but will double check, I have noticed that a couple of parts are now made from the ali tube stock supplied instead of being castings as before. Like the Camel it looks a well thought out kit to build and will be starting it soon.
#10 Posted : 30 May 2016 23:22:42
I do like the looks of these kind of kits, they're stunning when done right. Look forward to following you on this one Andy, good luck with her.....
This page was generated in 0.155 seconds.
