Propeller Options
ALW
#1 Posted : 22 May 2016 13:16:20
Hello
Having a run of problems one way or another!
I've screwed the brass screw into the brass shaft securing the gear wheel
to the backplate but the shaft is loose and I cannot tighten the screw any further.
In turn this is not allowing the prop blades to rotate.as the gear wheel is 'floppy'
Any ideas?
Thank you
#2 Posted : 23 May 2016 08:11:08
The screw is slightly overlong. Carefully file off appox 0.8mm - 1mm from screw thread.
See post #343 here
http://forum.model-space...sts&t=8666&p=18
ALW
#3 Posted : 23 May 2016 08:21:23
Thanks Tomick
I used a washer in the end. Will this cause problems as I noticed in the post
you sent the link for suggested not using one?
Thank you.
Regards.
#4 Posted : 23 May 2016 08:24:22
If you re-read the link, I say that reducing the screw length does away with the need for a washer., personally I would reduce the screw lenghth as there is less chance of it loosening with use of a washer.
