Landing gear Options
ALW
#1 Posted : 20 May 2016 15:08:55
Hello all
I've drilled a 2mm hole in the fairing screw housing but when driving the screw home
the housing has split.
I did this carefully as I am aware the metal is soft but it's happened twice.
Any ideas to rectify this?
Thank you
#2 Posted : 20 May 2016 15:59:59
It will only split if the screw is way too tight when being screwed. Hopefully you've not split all 8 mount holes. Try a slightly larger bit or a touch of lubricant on the screw thread to assist its entry.
The mount points can only be rectified with a replacement diecast fairing parts.
ALW
#3 Posted : 20 May 2016 16:09:58
Hi
Thankfully I will still be able to fix the screws. I am going to fill the mounting holes with 2 part araldite to hold the screws in their permanent fixed position.
Thanks for the advice
This page was generated in 0.392 seconds.
