Joined: 25/04/2010 Posts: 748 Points: 2,285 Location: bognor regis
the gun port frames will be sanded flush with the planking and once i have sanded all the planking i will apply a second planking to give the gunports a recess cheers benny
Excellent work and looks fantastic!!!
the cutting of all the gunports are now finished..i am not framing the upper deck gunports yet i will wait and see what comes with the build parts as these will be seen from both sides...the planking is also sanded and is smooth and is ready to receive the second planking later in the build  cheers benny
 cheers benny
Very impressive mate!!! Like it ALOT!!!!!!!!
cheers jack..theres alot of work to do yet to get this how i want it cheers benny
Joined: 25/03/2010 Posts: 472 Points: 1,357 Location: Hyde
Hi mate Great build so far. You've said about second planking - this build is single planked I'm afraid unless you doing second layer yourself. Keep it up. benny wrote:the cutting of all the gunports are now finished..i am not framing the upper deck gunports yet i will wait and see what comes with the build parts as these will be seen from both sides...the planking is also sanded and is smooth and is ready to receive the second planking later in the build
hi tom..thanks for your comment..yes i do know, i have ordered 37,000 mm of 5x0.5mm planking for later to get a recess around the gunports cheers benny
Joined: 30/03/2010 Posts: 126 Points: 335 Location: Bradford West Yorks
Hi Benny looking really good I'm not far behind you with the planking but now having seen yours I am seriously thinking of double planking what wood are you using keep up the good work
yorkieboy1 wrote:Hi Benny looking really good I'm not far behind you with the planking but now having seen yours I am seriously thinking of double planking what wood are you using keep up the good work hi..i have ordered walnut 5x0.5mm i worked out it will need 37,000mm just to plank the upper half..paul cheers benny
confession time ..i messed up the supplied barrels so i bought 4 more from cm,i have carved the lines in the barrels and stained and painted the rings  cheers benny
and also cut out the ports underneath the stern  cheers benny
hi all been a while since my last instalment..i have been trying to complete the bottom hull planking this week but dont think i will finish so i thought i would take a few pics..as i am second planking i havnt been to fussy with getting the planks spot on,but just wanted to get them flat to the ribs and curves in the right places..my aim at the moment is to finish planking get it filled and sanded smooth before i concentrate on anything else  cheers benny
 cheers benny
 cheers benny
 cheers benny
 cheers benny
 is it that bad  i thought so so i changed the pics for clearer ones..not very good at taking pics cheers benny
heres a cl;ose up pic of the stern..as you can see my planking needed a bit of tapering  good job i am second planking  cheers benny
