Stage 43 correction Options
#1 Posted : 15 May 2016 12:39:27
Note: There is a correction in Step 6 photo in the Stage 43 assembly guide, the motor cables of the X- and Y-axes are shown plugged into each other’s sockets. The proper positions for the cables are shown below. Instructions for fitting the cables correctly are given in Assembly Guide Stage 39.
AgentReverie
#2 Posted : 07 August 2016 16:16:17
Just to double check, bear with me please.
The guide I received with the parts show the correct way?
I should follow the step for Stage 39 and everything will be good to go?
#3 Posted : 07 August 2016 17:04:24
You should fit both plugs as shown above, all else in 39 is ok.
This page was generated in 0.095 seconds.
