round frames too big issue 76 Options
petrg
#1 Posted : 14 May 2016 04:45:13
Rank: Newbie
I'm up to issue 76 stage 19 taking the 16 round frames but they are too big to fit
The frames have an outside diameter of 12.52mm the holes are 8.25mm. This wouldn't normally be a problem as I would enlarge the hole but the wood on the forecastle is only 9.5mm. This applies to all of the above gunwales.
Any help please?
#2 Posted : 14 May 2016 06:59:22
Hi petrg the frames are fitted to the outside of the gunwales as the centre of the hole matches the hole in the gunwales so you don't have to open them up. I made the frames thinner by filing them down to half their thickness as they looked to thick.
Take a look at MR Ts official build and it shows it very well
Hope this helps rgd Martyn
petrg
#3 Posted : 14 May 2016 23:18:59
Rank: Newbie
thank you for your help. I will go for the filing down and place them on the outside
#4 Posted : 15 May 2016 06:34:54
No problem Petrg looking forward to seeing your build
This page was generated in 0.145 seconds.
