 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,188 Points: 15,713 Location: ipswich
When I try to view the official build, most of the time the pics don't show. I just get a small box with 'jpeg...' in it.
Everything else on the forum works - just not the official build. Is it just me? How can I fix it?
Roy.
Joined: 19/05/2015 Posts: 1,419 Points: 4,272 Location: Darmstadt, Germany
Attached pics have never worked for me. I can maybe see 1 in 20. If I reload 50 to 100 times there is a slight chance the 1 in 20 has worked out in such a way that I've seen all the pics on any given page by the 100th reload. The only time I reliably see pics is if someone used a dedicated image hoster instead of the attachment function.
roymattblack wrote:When I try to view the official build, most of the time the pics don't show. I just get a small box with 'jpeg...' in it.
Roy. As your a regular MS visitor, I would have thought you would have already been aware of this longstanding problem which has been reported in the Errors topic numerous times. Which is something that is affecting ALL direct upload images and also often affects file share hosted images across the forum. Generally a page refresh restores the photos. http://forum.model-space...spx?g=posts&t=14875
Our Tech guys are exploring possible solutions as so far an easy fix has evaded them.
I might add that Smileys are not currently operable.
Most people have access to some webspace from their ISP these days, with simple instructions how to use it
It is better to cut down the photos to 800 x 600 px and ftp them up. You can then put a link to them on the page.
