8 Pages 123>»
Photos Options
ALW
#1 Posted : 09 May 2016 22:11:09
Buying the remaining packs, 17 of them, was the best decision for me.
I've progressed very quickly (having a very understanding wife),
I've attached some pics of said progress.
I've made a few mistakes along the way but there is always a way around them, you just need to know how to get round them!!
Finally decided on Humbrol 36 (matt) for the interior colour.
Model is coming along nicely without too many difficulties other than
there are not enough hours in the day to make it!
ALW attached the following image(s):
#2 Posted : 09 May 2016 23:24:41
Looks good Alan, looks like your efforts are paying off..... well done....
ALW
#3 Posted : 10 May 2016 07:34:51
Thanks for your comment Alan.
My biggest concern was that some of the wing plates were slightly dented,
but having looked at the way some panels are fitted to the real aircraft
there's not a lot of difference so using that to my advantage and actually
looks realistic!
I've just got to find somewhere to conceal the engine sound PCB and speaker
and just ordered the landing gear motor.
Cheers
#4 Posted : 10 May 2016 07:47:41
If you resize you photos to around 450x600 they will appear as images rather than downloads
ALW
#5 Posted : 10 May 2016 08:04:14
Ok, thanks for the advice will bear it in mind for next time.
#6 Posted : 15 May 2016 08:57:39
Hi Alan having trouble opening your pictures.
Trev
ALW
#7 Posted : 30 May 2016 11:30:21
Hello Trev
Only just seen your post, sorry it's taken a while to respond.
I will try and resize the photos. I will have some more soon, the build is going well.
Cheers
#8 Posted : 30 May 2016 11:55:39
Hi Alan,
Looking forward to viewing your latest pictures, it is always a pleasure to see how you are getting on, as we speak I can here a Spitfire flying around from Biggin Hill guess it has been in for a service as it was flying around yesterday.
I'm nearly ready for a update myself on the tailplain, hope you have had a good bank Holiday.
Trev.
ALW
#9 Posted : 30 May 2016 12:17:40
Hello Trev
My wife was living in New Addington when we met and one year the airshow was on
we saw a spitfire and ME109 in a dogfight at low level, this was just something else,
god knows what it must have been like living in the area during the war-the distinct
sound of the Merlin is just unbeatable
Who doesn't love a Spitfire?!!
I'll post some pics ASAP, I've been trying to resize the photos-without luck-must
hone my PC skills!
Hope your BH is going ok?
Cheers
ALW
#10 Posted : 23 June 2016 10:31:33
[quote=ALW]Hello Trev
hone my PC skills!
Cheers
Alan[/quote
Wasn't happy with the fuselage panels so made the decision to tidy them up
using a polyester filler. Not a decision I made lightly,there was a compromise over
the rivet effect but I will overcome that once I have finished the build.
I searched the internet for how the panels look on the real aircraft and compared them to mine and hundreds of different Spitfire models of all scales, and decided it was best to go along the 'filler' route. I am very happy with the look now and although good progress is being made it is a worthwhile time-consuming task.
I have never undertaken a model like this before but I know once it's done it will look good-I'll make sure of it!
#11 Posted : 01 July 2016 22:49:19
Hi Alan,
Certainly look's different, but it will give you a very smooth finish, and when painted will be looking very smart. Will you be painting by brush or by airbrush.
Trev.
#12 Posted : 01 July 2016 22:54:20
Hi Alan,
Trev.
ALW
#13 Posted : 01 July 2016 23:05:47
Hi Trev
Different yes, looks good in the flesh! I admit it is extra work but definitely worth it. I was worried about the rivet marks but I think I have a solution thanks to our friends in the US.
My intention now is to grind the pin heads down to the size of the rivets and add more rivets accordingly. I have been practising and I think it will work but will require a lot of effort.
Where I have used filler, naturally the plate edges are now not visible but a small
engraving tool set at the right depth should resolve this.
Progress has gone slow again at the moment due to work commitments but hopefully wont be too long before I can get back onto it!
I will be spraying it.
Hope all is well with your model and yourself of course.
More pics to follow
ALW
#14 Posted : 13 July 2016 13:08:22
Tow more pics of the engine (dry test). I've noticed the port side exhaust mainfold
is upside down (note the machined marks). Quick rub down, all sorted!
ALW
#15 Posted : 13 July 2016 16:20:20
Been busy working on the spitfire since 07.30 this morning, making good progress.
I must confess I am keen to get it finished to see it in all its glory!
The fuselage looks a mess at the moment as I have been using it to test different paints, filler and the rivet decals. The rivet decals are quite good but slightly smaller than they should be but I think I'm going to stick with them.
However I can see the light at the end of the tunnel. Hoping to have the cockpit interior finished by Thursday.
More pics to follow.
Regards.
#16 Posted : 14 July 2016 21:30:11
Hi Al.
Looking a very nice build. look forward to seeing your progress,
Ian.
ALW
#17 Posted : 14 July 2016 21:39:52
Hello Ian
Thank you.
Been a bit of a challenge I must say! Only ever made
plastic kits before up to 1/24th, however now its taking shape I'm really
pleased with it and cannot wait to get it on the stand as I have a plan
for it but need to keep that quiet for now in case it doesn't work out-watch this space!
Cheers
#18 Posted : 15 July 2016 21:41:13
Alan,
Just catching up on the Spitfire builds, looking at that Merlin engine and cockpit you have made an outstanding job of it, looking along the fuselage it all seems to be shaping up very well, I will be interested in the paint work when you have completed it.
Thanks for posting
Trev.
ALW
#19 Posted : 15 July 2016 21:44:21
Hi Trev
Thank you for your comments-gratefully received!
I'm one of those people if I painted it and it wasn't right I'd rub it all
down and start again! Perfection springs to mind or my wife's preferred choice-OCD!!
Have a great weekend
#20 Posted : 15 July 2016 21:55:13
Just love that reply.
Trev
8 Pages 123>»
This page was generated in 0.289 seconds.
