Many thanks Moonman for the compliments. I look forward to seeing yours when finished, I spent hours on mine before I was happy with it. Mark Regards Markwarren (Mark) Admin
Okay, been tinkering whilst waiting for the next lot of issues, which came yesterday. I was looking at the model last week, whilst painting the hull parts and wasn’t happy with the cutaway plastic piece which holds the battery pack in place. As I am not using the battery pack, going for the mains route, I was wondering what I could do with it to make it look like it belongs to the hull area. I started painting it with metalcote paint with the thought I would rust it up a little so it didn’t look out of place.
Then things started getting a little more adventurous, after looking at my Haynes manual, so started measuring and made a sketch of what I wanted. Below this area is a freight loading room, so with reference pictures and my own drawing, I took the plunge and started. I still have a long way to go, but though I would post to get your thoughts.
I still have all the lighting to go in, such as red light by each doorway, green glow light under the grill and some danger signs and piping/wiring etc, but hopefully you get the idea. I am also cutting a section out of the power pack piece and weathering it to match the other hull pieces and painting the frame that is exposed black, then weathering that to give the appearance of a steel hull, rusting in places. Still it keeps me busy. Thanks for looking
Many thanks Mark Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
Joined: 16/03/2016 Posts: 122 Points: 381 Location: Layton, Utah
Wow! Nice bit of scratchwork there! Once again, you guys have managed to make me shake my head in amazement! If at first you don't succeed,
maybe you should skip the chainsaw juggling...
Joined: 04/07/2015 Posts: 99 Points: 309 Location: north wales
Nice work mark... Great idea ... As ive said before this is the benchmark build Top stuff
Great idea and looks like you are pulling it off too, excellent work!! Can't wait to see it finished
Absolutely amazed at what you Falcon builders are doing with this build, top work!
Many thanks guys, I'll post when finished, I have been putting the remaining frame together with the parts I received yesterday. Painted the exposed area of the frame black, ready for weathering to look more like steel gurders. Looks a lot better now I've put the hull pieces back on. Many thanks for all the encouragement Mark
Joined: 08/02/2015 Posts: 274 Points: 812 Location: Malmesbury
Looking good as always Regards Shaun Building-RC spitfire Build- titanic,Skyrider drone, solar system, T72 tank
Hi Mark. Very nice Build, fantastic weathering, keep the pictures coming Ian. Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
 Looking good Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Joined: 05/03/2015 Posts: 561 Points: 1,713 Location: South Carolina
Love the idea below the battery box! Very nicely done my friend!
Hi, thanks for all the encouraging comments, most appreciated. I have been doing a little more to the freight room last night, before I get involved with painting the remaining hull area. I still have some more lighting to go in by the other doorway and there will be some ambient green lighting under the flooring as there is in my hold area. Just a few bits of piping and some wiring that will connect to the hold area, then I’m finished, not too much different from my original picture. The last photo is where I have cut the battery cover which will be weathered and painted the same as the hull. Thanks for looking. MarkMarkwarren attached the following image(s): Regards Markwarren (Mark) Admin
Very nicely done... I was thinking of painting my frame too to give it a more gunmetally feel to it as well! :) Don't forget the frame over on the corridor walkway! :)
Many thanks Ade, I have really enjoyed doing it, didn't think it would work when I started it, but very pleased. I know its not as polished as some of the parts we get, but thats my own mark I have put on it. Pardon the pun  LrdSatyr8 : Many thanks for the heads up, missed that, as the cutaway section is still taped on the inside, whilst I was painting the hull. Many thanks Mark Regards Markwarren (Mark) Admin
Just thought I would give an update to my Cargo area, still some more to do on the framework with some greebies, wiring and piping but the pictures should give some idea. Once this is done, I’ll complete the painting of the remaining hull sections. This is a picture of the cargo area with the ambient green lighting below the floor grills and how I wired them together and the top hull section resting on it, with the hold area and the weathered front panel. There is also a ducting pipe, with more to follow.
Here is just a bit of fun video I made, help from BB8 with my lighting. https://youtu.be/sJWJ86H3L0w
Mant thanks Mark Regards Markwarren (Mark) Admin
Ha! Cute idea!  If at first you don't succeed,
Joined: 06/08/2015 Posts: 276 Points: 817 Location: Monrovia, Ca
I love the extra interior idea you came up with, Mark. I might have to steal that idea when I get that far along. Your build is looking amazing. Stephen Current Builds: HMS Sovereign of the Seas /// Lamborghini Countach /// Eaglemoss BTTF DeLorean
Finished Builds: Millennium Falcon
Thanks for the comments, GoofyFoot, Stephen. To think it all started out as an experimement. Regards Markwarren (Mark) Admin
