planking question Options
secretreeve
#1 Posted : 19 October 2010 04:28:03
hi can someone please tell me the dimensions of the supplied planks for the victory? im only on 13 atm so a few more dispatches away but im looking and using the traditional method of trennails to attatch the planking as well as glues.
trying to go for as realistic look as possible but need to know the planking dimensions in order or source the relevant doweling.
also what wood is the real victory hull made of? it splips my mind.
RussG
#2 Posted : 19 October 2010 05:45:12
Hi, The planking in the build is 5mm x 2mm and
Victory was constructed from approximately 6000 trees, 90% of which was oak.
This equates to 100 acres (40 hectares) of woodland.
Hull thickness at waterline - approximately 2ft (0.6m)
Timber types used for hull - oak, elm, and fir.
Timber for masts & yards - fir, pine & spruce.
Lignum Vitae - small quantities used for various applications
Hope that helpsBigGrin
Happy Building, Russ
On the workbench: My Victory Build Diary - Victory Cross Section Build Diary - Black Pearl Build Diary
Under the Bench: Millenium Falcon, Black Pearl x 2, Coral Victory Cross Section, De Lorean
#3 Posted : 19 October 2010 14:42:00
Assuming a trenail was 1" (just a guess) then your scale ones will have to be about 0.3mm to be in scale.
This can be done by drilling some progressivly small holes in a piece of steel (tool steel or carbon steel would be ideal). Then draw bamboo splinters through them to make the fine dowel. If you glue them in a 0.3mm hole, you can just snap them off and them will be flush with the face of the plank.
Challenging, but not impossible.
willie
#4 Posted : 19 October 2010 15:29:18
trenail a wooden dowel holding a ship side plank on i dout it you will find its a metal rod with around head and a washer on the other side with the other side bent over a wooden plug covers the head of the rods ,wooden boats use long bolts to day worked in a shipyard where wooden boats were bulit never heard of awooden nails but in jokes because wooden planks take ahell of strain to bend especialy 8" and a wooben pin to hold them in
secretreeve
#5 Posted : 19 October 2010 15:40:11
thanks for the info guys.
definatly going to be a challenege, but having scaled trennails would add to the realisticness of the ship in my oppinion. i think i'll give it a go on the sark first though.
willz
#6 Posted : 19 October 2010 18:56:11
A treenail, also known as a trenail or trunnel, is a wood peg or dowel used to fasten pieces of wood together, especially in timber frame construction and wooden shipbuilding. It is an ancient technology. Covered bridges in the U.S. often use treenails as fasteners. Many such bridges are still in use. Locust is a favorite wood when making trunnels in shipbuilding due to its strength and rot resistance.
A method of making such a fastener was to cut a parallel peg of a softer wood, and then expand its outer end with a wedge of much harder wood driven into it.
Ancient shipbuilding used treenails to bind the boat together. They had the advantage of not giving rise to "nail-sickness" which is a term for decay accelerated and concentrated around metal fasteners. Increased water content also causes wood to expand, so that treenails gripped the planks tighter as they absorbed water
#7 Posted : 19 October 2010 19:28:02
Try this extract from a book on Google Books for more info.
http://books.google.co.u...g%20trenail&f=false
(Hope the link works !)
#8 Posted : 19 October 2010 21:16:30
secretreeve if you go to index,lookup karls tips and tricks Iexplain how it is done.
