4 Pages 123>»
MFH 1/12 GTO engine kit Options
#1 Posted : 26 April 2016 16:12:21
Well after my crash and burn on the MFH 1/24 Daytona Cobra I decided to try my hand at their 1/12 GTO kit.
This is a mostly white metal kit with some clear resin parts so you can see the pistons moving.
Here is a video showing the tappets moving
https://www.youtube.com/watch?v=8awmlGsSjLM
It has hundreds of tiny white metal parts, some wire and some decals. The instructions are pictorial and pretty good.You have to drill about a million tiny holes to facilitate assembly so I set up my drill press with a micro compound table so I can accurately place the parts for drilling. I will be keeping a count of how many holes I drill in this kit, but I know right now it will be a LOT of holes.The holes are 05.,0.6, 0.8 and 1.0 mm in diameter.
Here are some pictures of the parts and instructions.
#2 Posted : 26 April 2016 16:19:08
We start with the pistons.They need clean up after removing from the sprue and then you have to drill 0.8mm holes into either side of the piston heads to pass a gudgeon pin to attach the connecting rods
So far 24 holes drilled.
michu
#3 Posted : 26 April 2016 16:56:37
Subscribed to updates. This is one of my dream kits so I'll be following with interest!
Happy building :-)
#4 Posted : 26 April 2016 18:05:00
This is a superb kit, will be watching and drooling!Drool LOL BigGrin
#5 Posted : 26 April 2016 18:08:07
Looks a top notch kit, is it the visible version?
https://www.hiroboy.com/...als--product--9297.html
#6 Posted : 26 April 2016 18:42:26
yes this is the visible version.One side of the engine is made from clear resin so you can see the pistons moving in the engine block.
#7 Posted : 26 April 2016 18:43:35
Should be a real treat Cool
#8 Posted : 26 April 2016 19:11:44
BigGrin Nice kit takes the working engine on the MP 4/4 to another level, will be watchingCool
#9 Posted : 26 April 2016 21:23:31
Hi Carl.
Look ford to seeing your progress.Cool
Ian
rjfk2002
#10 Posted : 26 April 2016 23:46:46
I will be eagerly following along. Are you cleaning the white metal by hand/Dremel or using a magnetic polisher?
#11 Posted : 27 April 2016 01:59:29
By hand.It is very soft.
#12 Posted : 27 April 2016 09:13:02
#13 Posted : 27 April 2016 14:18:00
Great looking kit.Cool Quite a challenge. I'll certainly be following this one.
#14 Posted : 27 April 2016 14:33:12
Hmm I feel a mystery purchase coming on!!LOL LOL LOL
#15 Posted : 27 April 2016 16:03:17
Wow, that's a seriously nice looking kit, should be a stunning display piece Cool
#16 Posted : 04 May 2016 15:57:37
More drilling.Here is a picture of my drill press set up.I have the micro compound table set up so I can accurately position the piece I am drilling.I have now drilled the holes in the pistons for the gudgeons and drilled the holes in the connecting rods so I can assemble the piston assembly.
It is a bit time consuming using the drill press, but it is the only way to get the holes exactly where they need to be.If i want the pistons to move in the cylinders I need to be precise.
total 36 holes drilled (all 0.8 mm).
#17 Posted : 05 May 2016 15:58:53
So here are the 12 pistons and connecting rods.You connect them with 0.8 mm brass wire and then assemble them on to the crankshaft
#18 Posted : 05 May 2016 18:42:52
Looking good and top work
#19 Posted : 06 May 2016 16:38:28
Now the pistons are connected to the connecting rods with the gudgeon pins and I started assembling the crankshaft.
The crankshaft is assembled in sections with 2 pistons per section.The ends of the crankshaft sections are keyed. I tried test fitting the pistons into the cylinder and it will be a very fiddly job to get them all in place and secured without getting any glue on the parts that need to move.
#20 Posted : 06 May 2016 16:53:12
And I thought a full size V12 was complicated!! Very nice build, and superb work.
4 Pages 123>»
This page was generated in 0.272 seconds.
