Joined: 26/03/2010 Posts: 146 Points: 473 Location: Plymouth
Well a very kind old friend has given me an old camera so now I can show you some of my Bodge jobs!!! Bodge def. = an attempt at the build with two left hands and poor vision...    ArtfulBodger Previous Build: HMS. Bounty
That is a fantastic pic and excellent build!!
Joined: 20/03/2010 Posts: 278 Points: 833 Location: Nottingham
Great photographs and very neat work. I see you have decided to plank the middle deck it looks very effective. Can I ask how long you made your planks? Pam's shipyard is closed for now no more room!
I planked the decks in halfs [using 0.5 x 4mm]and then seated the decks and used one long strip to cover the seems. My technique for planking was to put a full plank on wet [ie. using pva glue] then cutting the strip up into lengths to give the planking effect. The length used was just about rib distance because I tried smaller, which would have been to scale but it looked too cluttered. A bit of poetic licence bearing in mind this is only the middle deck. ArtfulBodger Previous Build: HMS. Bounty
Pics are great, and really impressive build. Well done.
The decks look fantastic and your planking is spot on!!
But won't it all be completely covered up?
John
Absolutely brill work there...very nice in deed, I noticed the top of rib 15 there?? in your progression from applying the first plank up to the stage where you are at at the moment, has this had any affect on rib 15, i.e is it drawing it into line???... Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
Jonny Rib 15 is a nightmare but we all know that. My theory is sand where necessary and rebuild where necessary. I've used some 0.5 x 4mm strips to build up where needs be. ArtfulBodger Previous Build: HMS. Bounty
Hi ArtfulBodger,
Great job on the build m8, What colour are your planks I really like that colour which would look nice on my HMS Fly instead of Tanganyka.
Thanks Chris..On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
mahogony 0.5 x 4mm. Glad to see you're back on top. ArtfulBodger Previous Build: HMS. Bounty
   I'm a bit slower than most of you but they won't let me take my build into the hospital. Still a few weeks and I'll be back at it hopefully! ArtfulBodger Previous Build: HMS. Bounty
Never mind slow, she's look good
now we are begining to find the real builders,what a neat and tidy build,shows mine up,--------------------gonna get hoover out. wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
Joined: 29/04/2010 Posts: 33 Points: 72 Location: chesterfield
hello Artful,
Amazing work there m8 looks nice....
Hope you don't mind me saying but at the rear parts numbered 34 are mean't too be sanded flush too the keel like on Tomicks.
Chris...  On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
