Frames Options
Page
#1 Posted : 22 April 2016 02:15:09
Rank: Amateur Level 1
Got my new surprise kit #1 and again found the parts not numbered as before, Danny at MS says that this kit is not numbered as it more advanced and I should have gotten the VictoryCrying Can one tell me how to get frames 10-24 in order as I am pretty sure I did not do this on my first try
Page
#2 Posted : 22 April 2016 08:33:54
Hi Page.
Did you get the frames on a sheet where you had to cut them out. If so the cutout sheet pdf that was sent to you shows a picture of the ply sheet and which frame is which.
http://forum.model-space...sts&m=9200#post9200
Chris. BigGrin BigGrin
#3 Posted : 22 April 2016 09:12:58
The pdf download for the cut/numbering sheet is on HMS Surprise web page under "The Build" tab
http://www.model-space.c...d-the-hms-surprise.html
This page was generated in 0.081 seconds.
