I have just received my second binder and it's slightly different compared with the first so I thought I would check with you guys before I ring CS tomorrow.
On the first one I received there was a small cover, top and bottom, that closed and locked into place to stop the plastic pins from falling out, as they indeed did if the cover was open while I was putting in the latest issues.
My new binder does not seem to have these clips. Is this a fault with mine or a manufacturing or even a redesign problem?
John
that definatly sounds like a majour fault.
although you could superglue th bottom pins in place and leae the top ones as they are incase you want to remove one of the issues.
secretreeve wrote:that definatly sounds like a majour fault.
although you could superglue th bottom pins in place and leae the top ones as they are incase you want to remove one of the issues. Do have have your second binder yet? John
 Rank: Pro  Groups: Registered
Joined: 27/03/2010 Posts: 188 Points: 614 Location: Llandudno
I had the same thought But I did notice when the binder goes in it tends to force the end of the clip into a recess. Bob
So your second one does not have the clip either as the first one did?
John
no i opted out of the extra binders.
i was just adding what came to mind in hopes it would help.
secretreeve wrote:no i opted out of the extra binders.
i was just adding what came to mind in hopes it would help. Thanks
Joined: 28/03/2010 Posts: 152 Points: 513 Location: Liverpool,England
Mine was different too. Different method of holding the clips in place. Seems to do the job though. Jimmy L.
current builds : Lancaster 1/32 (Hachette) Revell USS Kearsarge Titanic Lifeboat
I started off with nothing and I've still got most of it left.
axle396 wrote:Mine was different too. Different method of holding the clips in place. Seems to do the job though. I am in the UK at present and my first binder in is Greece. How is it different? It looks the same to me but without the clip. John
z8000783 wrote:axle396 wrote:Mine was different too. Different method of holding the clips in place. Seems to do the job though. I am in the UK at present and my first binder in is Greece. How is it different? It looks the same to me but without the clip. John One(the first) has a little hinged flap that snaps closed to hold the little pins in place and the other has a recess that you have to push the pins past to secure them. Both work fine. Jimmy L.
axle396 wrote:z8000783 wrote:axle396 wrote:Mine was different too. Different method of holding the clips in place. Seems to do the job though. I am in the UK at present and my first binder in is Greece. How is it different? It looks the same to me but without the clip. John One(the first) has a little hinged flap that snaps closed to hold the little pins in place and the other has a recess that you have to push the pins past to secure them. Both work fine. Thanks Jimmy, I shall have a look before hitting the phones. John
