21 Pages «<910111213>»
1/24 Schnellboot With R/C Options
#201 Posted : 13 April 2016 11:54:55
she`s looking great AndyCool regards Phil
#202 Posted : 13 April 2016 19:04:40
BigGrin Hi Phil
#203 Posted : 13 April 2016 19:55:14
BigGrin Looking good Andy Cool
#204 Posted : 14 April 2016 18:36:49
BigGrin Hi Martyn thanks for looking in and your commentsCool
#205 Posted : 17 April 2016 19:52:08
BigGrin Hi All
As you all know I was not happy with how the last level/screen of the upper Skullcap looked so after striping it back and deliberating how would be the best way to do it I decided to draw a full size plan of the upper row of facets and built the new screen on this. When it was dry it was placed on the scull cap and adjusted to fit. Now I am a happy bunny with how it looks as this is the 1st thing people look at when looking at the model as the eyes seem drawn to that particular point. Now I can proceed with the rear deck coversBigGrin . More soon.
#206 Posted : 17 April 2016 20:06:16
Very nice update.
Glad to see you got the parts sorted.
#207 Posted : 17 April 2016 20:49:22
BigGrin Looking good Andy very nicely done Cool
#208 Posted : 17 April 2016 22:04:07
Nice work Andy,this build gets bigger and bigger.
Trev
#209 Posted : 17 April 2016 22:55:24
BigGrin Thanks everyone for looking in and your commentsCool
#210 Posted : 18 April 2016 12:16:06
Very nice work Andy ThumpUp Cool
#211 Posted : 18 April 2016 19:16:52
Hmmmm that looks better, very nicely done!ThumpUp
#212 Posted : 18 April 2016 21:47:35
BigGrin Thanks for looking in and your comments both of youCool
#213 Posted : 08 May 2016 16:54:56
Hi All
I will be back on this in a short while and this is just an update on the Mixer set I will be using. Starting with the marine motor mixer this will enable the two outer motors to be controlled on the turn in effect slowing down the inner motor as you apply more rudder to port or starboard. The next unit is the multi controller which has an onboard ESC that will kick in the central motor at a set point from say half throttle upwards. They also do a very nice 3 motor power distribution board which I am awaiting its arival. More soon.
#214 Posted : 08 May 2016 21:59:44
Hi Andy looking great.that bridge looks very tricky to do.you done superb job on it.look forward to more cheers mick.
#215 Posted : 08 May 2016 23:45:45
Top looking good, glad you got it sorted and the electronics side looks very interesting.
Looking forward to seeing that side of it come together.
#216 Posted : 09 May 2016 13:06:08
Hi Andy.
Looking very nice. Keep up the good work.
Regards Ian.
#217 Posted : 09 May 2016 21:05:27
Thanks everyone for looking in and your comments.
#218 Posted : 19 June 2016 20:25:19
Started doing some more on the boat and just a small update for now. I have started making up the main engine cover. the base for the cover is the piece that was cut out from the deck this was then strengthened underneath using the cross pieces already cut from the section to create the access hatch and then side pieces and strengthening fillets added to the joints. Finally a new top piece was made up that is 2 mm wider all around than the original deck piece so there is a neat joint with the deck. Once the glue is dry I can start adding the deck furniture on this part. I may yet stiffen it up some more as this part will be taken off more often that the other hatches and might need it. More soon.
#219 Posted : 19 June 2016 22:40:32
Progressing nicely Andy, lovely work....
#220 Posted : 19 June 2016 23:30:45
Thanks Alan feel like things are falling in place now with this and thanks for looking in and your comments
Guest (6)
This page was generated in 0.214 seconds.
