29 Pages «<7891011>»
karls new victory build Options
#161 Posted : 17 October 2010 09:33:04
thanks tomick,but will be double planking and veneering second layering,and then varnish below waterline,another thing that has cropped up,that doe's concern me is,the pics of the old girl on face book shows the gunports with a picture frame around them,it this one the same???if so, no way am I going to do that,totaly wrong and looks it,will stick to framing inside of gunport.
ArtfulBodger
#162 Posted : 17 October 2010 10:47:24
Karl
My admiration for having the determination to replank.The precision of your work is outstanding.
ArtfulBodger
Previous Build:
HMS. Bounty
jonny7england
#163 Posted : 17 October 2010 12:09:52
Karl...After all the hard work you put into your model..I admire the guts it took to rip off all the old planking and starting from scratch again...a task, I would have had ruddy nightmares about before doing such a thing...I doff's me hat mate in admiration...keep us posted, its looking good so far mate...
ThumpUp
axle396
#164 Posted : 17 October 2010 18:10:02
You have the patience of a saint Karl. My ghast is well and truly flabbered.OhMyGod
Jimmy L.
current builds : Lancaster 1/32 (Hachette)
Revell USS Kearsarge
Titanic Lifeboat
I started off with nothing and I've still got most of it left.
#165 Posted : 17 October 2010 21:52:41
Karl, not that far ahead to see as yet, but the gun and entry ports are certainly lined, which is at 34/35.
secretreeve
#166 Posted : 18 October 2010 13:28:19
hi karl. what are the depth and thinknesses of the walnut planking you have used?
thomasmoult
#167 Posted : 18 October 2010 16:55:51
Thanks Tomick, we are to start the lining for the gun/entry ports at issue 34/35?
Do you know what wood is to be supplied?
Cheers mate,
Tom
#168 Posted : 19 October 2010 09:44:22
secretreeve, futher up the page I said 5X 2mm X 1000mm BEECH. walnut too dark.
#169 Posted : 19 October 2010 10:20:08
this is what I meant 'bout the framing of the gunports,pic is from de-ags facebook
#170 Posted : 19 October 2010 21:01:37
starting the portholes.
#171 Posted : 19 October 2010 21:03:09
#172 Posted : 19 October 2010 21:04:19
#173 Posted : 19 October 2010 21:04:39
Well done m8y BigGrin .. Looks nice in beech, I take it your staining her... My Planking is taking ages without using pins.. have to do one row at a time...Crying
Chris..
#174 Posted : 19 October 2010 21:05:43
#175 Posted : 19 October 2010 21:12:16
maggie,the beech doe's have it's drawbacks,it is very hard,need to drill out the gunports,and sanding is taking ages,even using power sander wears out the pads.looking on e-bay for diamond sand paper,had it years ago,you can't wear it out,it is metal sheet coated in copper with industial diamond in it,was'nt too expensive neither.it was incorporated into a sanding block.ever seen one???? if not,keep an eye out for one,I mean your good eye. Blink
ArtfulBodger
#176 Posted : 19 October 2010 21:29:04
Wow, Karl you must never sleep, how the hell did you get all this done. Well impressed, a very gutsy move to replank and you've already overtaken me and recovered. Looks excellent!!!
ArtfulBodger
Previous Build:
HMS. Bounty
#177 Posted : 19 October 2010 21:40:01
Hi Karl,
Have you tried these
http://www.permagrit.com/
#178 Posted : 20 October 2010 10:28:04
thank you mr.t just the job,been looking for months,ordered up and waiting........
Son of Bulwark
#179 Posted : 20 October 2010 15:12:03
Hi Karl! BigGrin
Well you beat that problem! replanked in double quick time, Fantastic simply Fantastic! had to say that twice it's that good. I'm still framing the mid deck gun ports had to many stops with the hospital last week not much time to build, you haven't had that problem.
I hope your happy with the way it all looks, keep up the good work Karl.
ThumpUp Darron
#180 Posted : 20 October 2010 15:27:10
thanks darren,arms dropping of 'er,sorry to hear 'bout hospital,keep yer pecker up m8,and don't let them grind you down.
This page was generated in 0.174 seconds.
