Pathway for wing lights Options
m0325
#1 Posted : 15 April 2016 18:01:42
What is the pathway for the two light cables from the wing tip to the battery box
#2 Posted : 15 April 2016 23:04:12
Via the most direct route, much the same as the Fus and Tail lights
#3 Posted : 16 April 2016 13:28:21
Hi m0325,
As Tom said the most direct route, so that means all the wires are arranged in the underside of the plane and a hatch which is supplied will keep them all enclosed, this will be under the cockpit, then just screw the wing back in place.
Trev.
