 Rank: Vice-Master       Groups: Registered
Joined: 07/01/2015 Posts: 856 Points: 2,479 Location: Sevenoaks, UK
Apparently, the original English version of the owner's manual of 2000GT. Would love to find a copy of the whole thing somewhere and have a chuckle of two... "To loosen the hub nuts instal (sic) the hub nut wrench to the hub nut and then drive out the hub nut wrench with the hummer in the tool set, carefully damaging theand disc wheel. Caution. Right-side hub nut is left-handred (sic) and left-side hub nut is right-handred (sic), therefore to loosen the hub nut turn the hub nut forward of the car."Or about the window de-icing: "Caution. Off the switch as soon as removing the blur."SourceAny images I post on my personal builds are free to be used and shared under Creative Commons Attribution license, which means you can do what you want with them, on the condition you mention I'm the author.
Happy building :-) http://www.model-space.com/gb/
