The final stages of planking Options
thomasmoult
#1 Posted : 16 October 2010 16:45:28
Hi everyone,
Just a quick question, think Tomick will be able to help; I am at the stage of drawing the 4mm onto the ribs to figure out the where the last plank will lie, but it seems some of my frames are not all of the same height - ribs 16 - 21 are all *roughly* the same height, but is it ok if there is a slight variation? The reason I ask is the magazine states 17-21?
Also, does the planking come up so it is flush with the very tops of the ribs? By this I mean in the end after any imperfections (too high, too short etc) will they end up flush with the tops?
Thanks,
Tom
#2 Posted : 16 October 2010 20:00:47
Forget about the other frames, the 4mm only relates to frames 17-21, the other frames are taken care of later on.
You plank up to the 4mm line, if over don't worry it will be sorted later on.
thomasmoult
#3 Posted : 16 October 2010 20:39:00
Thanks Tomick,
Have studied the pictures carefully and it looks the same.
Cheers,
Tom
This page was generated in 0.080 seconds.
