Wing plates Options
ALW
#1 Posted : 10 April 2016 21:31:19
Hello all
Just started to assemble the wing plates,which glue is best?
All suggestions welcome! BigGrin
Regards.
#2 Posted : 10 April 2016 22:36:54
Hi Alan,
Just got back from a weekend away and read your post, I think you can use several types, for my build the plates are drilled and screwed together, and were I did glue ( around the tail fin ) I used Gorilla, but I think others use gel super glue which will give you time to move it if need.
Trev.
ALW
#3 Posted : 10 April 2016 22:46:12
Hello Trev
Hope you had a good weekend?
I messed up the very first wing plate-fitted it the wrong way round!
Never mind. I've got some of the gel glue so will have a little practice beforehand, don't want to make the same mistake again.
Thanks for the suggestions.
Cheers
#4 Posted : 11 April 2016 10:54:43
Many builders use "Evo-Stik Timebond" for gluing skin plates or copper tiling on Ship hulls. Its a contact adhesive which gives time to position before bonding permanenlty, available in tubes and tin's.
http://www.bostik.co.uk/...uct/evo-stik/Timebond/7
Be mindful that some glues (such as standard Superglue), become brittle when set, which over time can cause a plate to pop-off. Superglue ultra gel is rubber toughened and is more resistant to knocks and vibration.
ALW
#5 Posted : 11 April 2016 12:03:42
Thanks Mr T
I'll experiment with a few I think. Be worth it in the long run
