3 Pages <123>
TheFlyingCouchBuild Options
#21 Posted : 06 April 2016 10:30:45
TheFlyingCouch wrote:
I wish the Lambo came as a complete kit. The Toyota is a cool kit.
Jon
The Countach will be available as a full kit once the Subscription has run its course BigGrin
TheFlyingCouch
#22 Posted : 07 April 2016 18:45:44
My 2000GT case arrived today!!
Jon
TheFlyingCouch attached the following image(s):
#23 Posted : 07 April 2016 20:09:44
BigGrin That looks the bizzCool
michu
#24 Posted : 07 April 2016 20:11:54
Got one too! :)
I need a bigger house...
Happy building :-)
TheFlyingCouch
#25 Posted : 08 April 2016 00:00:59
Yeap, well i am having a man cave built soon, for all my kits and collectables!
Jon
TheFlyingCouch
#26 Posted : 11 April 2016 21:26:43
Stages 11 to 21 now completed, no problems but be careful with the distributer leads. had to use a little glue to secure them in place.
Jon
michu
#27 Posted : 11 April 2016 22:04:18
Nice job. Did you glue in the battery leads too? There are replacement cables provided in Stage 59 that are pointed to the left instead of to the right, which makes them fit better when installed into the car body.
Happy building :-)
TheFlyingCouch
#28 Posted : 11 April 2016 22:32:11
No i have not glued the battery leads, thanks for the advice!!
Jon
TheFlyingCouch
#29 Posted : 19 April 2016 21:43:12
Stages 22 to 30 now completed, be carful with the tiny dashboard switches, use a decent pair of tweezers!!
Jon
#30 Posted : 19 April 2016 22:23:04
BigGrin Looking very niceCool
#31 Posted : 19 April 2016 23:09:14
Wow, looking good Jon, awesome build ThumpUp
michu
#32 Posted : 20 April 2016 00:31:39
Great work :)
How do you find the gear shift lever? In my opinion that's the most fiddly part of the whole build; I wasn't able to assemble it without CA glue.
Happy building :-)
#33 Posted : 20 April 2016 03:01:15
Hi Jon,BigGrin
Looking good so far, thanks for pointing out the odd bits that need extra attention . Will come in handy when I get round to building mine.Cool
Keep up the good work.
#34 Posted : 20 April 2016 06:37:45
TheFlyingCouch
#35 Posted : 20 April 2016 07:05:48
Thanks for the comments, the Gear lever assembly took a little play to get it right. What i found best was to insert the base first into the body of the car, lining up the small projection, then i added the gaiter and finally the lever.
Jon
#36 Posted : 26 April 2016 21:19:39
Cool great looking BuildBigGrin
Regards Ian
#37 Posted : 26 April 2016 22:45:24
Great progress Jon, looks fab.... Cool Cool
#38 Posted : 27 April 2016 22:24:52
Great to see your making good progress with your Toyota 🚘.😎 The engine looks very detailed. Are you planning a straight ootb build of are you going to add few little tweeks.
Chris 👍
TheFlyingCouch
#39 Posted : 28 April 2016 17:50:29
No Tweaks just a straight build!!
Jon
steviecav
#40 Posted : 17 May 2016 16:46:34
Rank: Amateur Level 1
Looking good. Can't wait to start mine. Hopefully it is arriving this Thursday.
3 Pages <123>
This page was generated in 0.189 seconds.
