 Rank: Pro  Groups: Registered
Joined: 27/05/2011 Posts: 256 Points: 774 Location: barrow in furness
Has anyone got any unused body decals that came with the build? I've managed to ruin one of mine while applying it. If at first you don't succeed........skydiving is not for you!
Joined: 02/03/2015 Posts: 84 Points: 245 Location: England
If nobody has any, these should do the trick. http://shop.autographmod...-stickers-DZUZ-many-moreBuilding the MP4/4!
Joined: 15/01/2016 Posts: 59 Points: 177 Location: US
Out of curiosity does anyone know the difference between some of sponsor/cigarette decal sets? For example does the cigarette set (D721) contain all the markings for the full car? It seems like the combination of front wing (D659), rear wing (D661) and sponsors (D720) covers all the sponsor/cigarette ads with D721 being completely duplicative.
I think D721 is all the Tobacco adverts you need: Nose, Body and rear wing. I think if you're just after the Tobacco decals it should do the trick. Building the MP4/4!
 Rank: Beginner Level 3  Groups: Registered
Joined: 03/07/2014 Posts: 27 Points: 71 Location: Baltimore, MD USA
scottww86 wrote:Has anyone got any unused body decals that came with the build? I've managed to ruin one of mine while applying it. Which ones did you need? Are you in the U.S.A.?
Not in the US sadly, I'm on the Isle of Man! Lol. I'm just after the "shell" ones for the radiator ducts on the side of the body. Cheers for the heads up on the other kits everyone, might just opt for one of them! If at first you don't succeed........skydiving is not for you!
Joined: 21/05/2014 Posts: 53 Points: 148 Location: Diss
Did you get the decals you wanted as I have some spare ones
