21 Pages «<7891011>»
1/24 Schnellboot With R/C Options
#161 Posted : 24 March 2016 00:21:15
Hi Andy.
Speeding along nicely. looking realy good Andy keep the pics coming Ian BigGrin
#162 Posted : 24 March 2016 18:43:05
BigGrin Hi Ian thanks for looking in and your comments hopefully should crack on with the bow and start adding some more deck features this W/E. Cool
#163 Posted : 25 March 2016 18:31:05
BigGrin Hi All
More done, the bow gun bucket was made from 3 pieces of 5 mm ply and some styrene pillars with a 1/32 ply liner this was then attached to the deck, the ply liner is proud because another deck section is to go on top of the central bow deck this extra will be trimed back after its attached.
Braces were added to the hull where the bow deck will be attached and then the deck was fixed in place with epoxy resin. Once the epoxy had set the deck edge gaps were filled with filler and now awaits a good sanding before the central deck is added. More soon.
#164 Posted : 25 March 2016 19:34:35
This is coming along quite nicely, I'm really enjoying this build ThumpUp
#165 Posted : 25 March 2016 20:25:52
Andy,
Starting to shape up now and we can see where you are going, but still a lot of work on this section alone.
Trev.
#166 Posted : 26 March 2016 09:11:27
BigGrin Hi both thanks for your comments and looking inCool
#167 Posted : 26 March 2016 09:16:10
Very inovative building with the gun basket.
Its movng along at a good pace now.
#168 Posted : 26 March 2016 17:58:09
BigGrin Hi Tony thanks for your comments and looking in, still have to work out how im going to build the skullcapCool
#169 Posted : 26 March 2016 18:15:08
BigGrin Hi All
The central bow section has now been glued in place and then filler was used from the torpedo doors forward so when it was sanded back the deck and hull blend together. The gun bucket was trimmed back and a small amount of filler used around the edges to tidy it up.
I couldnt resist adding some fittings so added the bow fairlead and the torpedo doors. Next its the skullcap and bridge and have started by cutting out some templates. More soon.
#170 Posted : 26 March 2016 18:42:23
Andy,
Just had look while working on the Spit looks good and with the door fittings I can see we are in for a treat.
Must crack on.
Trev.
#171 Posted : 26 March 2016 22:26:05
That`s looking good, Love Love .
WTG Andy, really taking on some shape now. Cool
#172 Posted : 27 March 2016 00:09:18
Now this is taking shape Andy, very well described too..... great work....Drool Drool
#173 Posted : 27 March 2016 00:50:03
BigGrin Thanks everyone for looking in and your replysCool
#174 Posted : 27 March 2016 10:19:22
The detail parts look good. Cannot wait to see the armament as its bound to be very detailed and should look brilliant when in place.
#175 Posted : 27 March 2016 19:25:51
BigGrin Hi Tony
Thanks for looking in the fittings kit although not cheap it has some quality pieces in it as you will soon see.
#176 Posted : 27 March 2016 19:42:02
BigGrin Hi All
Started on the scratch build of the skullcap by fixing the first 5 formers in place . Next the bottom row of plates were added the two side pieces go across to the hull sides and back to aid location the running light housings were fixed in place and then the hull sides were built up to match, the inner hull sides were also lined with 1/32 ply to give a backing for the built up parts. The skullcap side decks were then added this will enable the fitting of the final four templates. The first facet has been fitted to the front of the skull cap but each one will have to be carefully sized to fit . More soon.
Andy Cool
#177 Posted : 28 March 2016 19:22:09
BigGrin Hi All
More progress on the bridge area. After measuring and trimming back the bridge side steps the main upper open bridge was measured up and constructed from 2 mm ply some scratch built bridge fittings were added along with some dummy doors and the rear box attached, still more to add here like handles and floor duck boards along with a raised portion around the forward central binocular area.
Once the central bridge area was fixed in place I could then proceed with the sides of the skull cap formers and managed to complete one side just the other side to do now and then the facets can start going on. More soon.
#178 Posted : 28 March 2016 19:34:34
Fantastic work, just had a catch up and this is going to be something special!!BigGrin BigGrin
#179 Posted : 28 March 2016 20:22:54
Wow, you're really moving along now BigGrin looking good ThumpUp Watching eagerly for your next update Cool
#180 Posted : 29 March 2016 19:17:23
BigGrin Thanks for looking in both of you and your commentsCool
Guest (12)
