 Rank: Beginner Level 3  Groups: Registered
Joined: 29/01/2016 Posts: 29 Points: 77 Location: Virginia,USA
Panzer Pug attached the following image(s):
Here's Bulkhead 15. I think I need a replacement, yes? Panzer Pug attached the following image(s):
Another photo. Panzer Pug attached the following image(s):
Here is the second section of the frame. The bottom of this is pretty straight. From what I can tell from the instructions, only the deck will sit on top of this, so I am not certain this needs to be corrected. The end, which shows the worst warping, should be fixed when I glue the next piece of the frame....I hope. Panzer Pug attached the following image(s):
 Yep I think frame 15 definitely needs replacing  brilliant job on the rest of the build Rgd Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Very neat job on the ribs. Loks like they have started cutting a much tighter fit on each 3 part rib build as your joints look really nice and tight. Glad you have sorted you picture posting as i could not see your earlier ones (system kept telling me i needed an active session to view them  ). Hope the rest of your build goes well. Happy Modelling
Hi, great to see you have the picture problem resolved. You can of course post more than one picture per post, this would save you having to create separate posts for each pic....  .. Vic is coming along very nicely but would highly recommend you put her in a jig to help ensure the keel is kept perfectly straight. The rigors of the early planking stage can pull the keel out of alignment creating bigger problems later in the build.....  .. Look forward to seeing your next update.... Regards Alan
Hiya Panzerpug. Doing a great job. I second Alan's comment of putting her in a jig as the keel may have a tendency to twist. Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Thanks for all the comments and recommendations for a jig.
Making one is my project for today. Headed to the local Lowe's in a couple of hours.
Jig completed. Very simple, actually. Panzer Pug attached the following image(s):
Hi, Looking good, shame about that rib 15 but I`m sure you`ll get the problem resolved with a replacement. Congrats on your "Blue" medal for producing a build diary. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Looking good.Your replacement part should arrive soon.Good job on the building jig-that will keep your Victory nice and straight!!
hi Panzer pug your build is looking very Nice. keep the pictures coming Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
