5 Pages <12345>
Here we go boys. Lets get this Falcon started Options
jaws062666
#41 Posted : 20 March 2016 23:07:52
Here is my ramp from issue 57. All is right with the world.
https://youtu.be/TlEaXp5iHnY
My current builds: The Millennium Falcon, Suzuki GSX 1300R Hayabusa, Ford Mustang Shelby
jaws062666
#42 Posted : 22 May 2016 23:38:45
I am done up to issue 68. I started my painting on the top hull. It is hard to believe that only 8 more shipments til it will be done.The only glitch I see is that when you attach the upper plates,it doesn't tell you to add the cockpit tube. It will not fit on after the plate is secured.If you screw it in and have to unscrew it later, the self tapping screws might not go back in. I have left the whole part unscrewed for now.
#43 Posted : 23 May 2016 12:54:18
Coming along nicely! Also some lovely weathering in the inspections pits
jaws062666
#44 Posted : 23 May 2016 14:07:37
Thank you.
colson
#45 Posted : 23 May 2016 21:29:44
Yea, I would hold off and wait to attach the tube until it tells you how in the instructions. I know some have already done it, but I myself am waiting to do it right just in case. I don't know about the unscrewing. I don't think the instructions would have us attach at this point, only to remove later. They're pretty good about doing things in the correct order and telling us to wait and something will be done at a later time.
#46 Posted : 26 May 2016 14:30:54
Looking good, nice to see it taking shape now. I've not screwed down my tube section either yet.
jaws062666
#47 Posted : 12 June 2016 17:31:38
I am all caught up to issued 72. This will finish the top engine section and the front cover for the interior. I have done the primary color painting, and just need to weather the top hull. There have been a few complaints about the front section fitting in correctly with the top turret screwed in. I have found this to be true as well. I don't know if DeAgostini will address this later, but there have been some fixes by other members given. One is to file down the little square on the front of the turret. Another member suggested putting springs in the turret so it has some give.I have not seen pics of that method, but it seems a bit drastic to me. I will most likely trim the piece of the turret off if no other solution is given.
#48 Posted : 12 June 2016 17:43:46
Looking good, got my next batch yesterday upto issue 73.
jaws062666
#49 Posted : 05 July 2016 14:49:14
Just got my month 19 shipping notice. Its hard to believe that there are only 6 shipments left until the end. I cant wait to see the finished results.
jaws062666
#50 Posted : 13 August 2016 14:19:18
I am up to issue 80 in my build. I am working on the top weathering and will post pics when that is done.I am posting some updated pics on my bottom frame though. I received the aftermarket light kit from Chris Holland for the bottom warning and landing lights. It is an awesome kit and really adds to the detail.
#51 Posted : 13 August 2016 15:03:31
Really nice work up to this point. The extra lighting does look awesome, I have extra lighting myself to go in.
#52 Posted : 13 August 2016 15:34:02
You are doing a top job with your build - it looks fantastic.
Just looked at your ramp video - cool, very cool indeed.
Hope the build continues to go well.
#53 Posted : 13 August 2016 16:01:42
Great job so far.
#54 Posted : 13 August 2016 17:55:18
Looks really good, still have mine to do. I have all the lighting and kit to make my own lights, as I did with the red/ mind your head lights, but I want to see how the rear hyper drive lighting unit will sit before putting any lights in the rear underside. Although they look as if they will be elevated from the frame. That aside, it does look brilliant and one enhancement I decided to do some time ago.
jaws062666
#55 Posted : 14 August 2016 02:03:17
Thanks for all of the comments guys. This kit is top notch. Kudos to Chris Holland.
tunko
#56 Posted : 24 August 2016 02:58:50
Rank: Amateur level 2
How Exciting! I have almost nothing from the top hull. So cool to see yours coming along so awesomely.
jaws062666
#57 Posted : 10 October 2016 20:34:43
I have been working on weathering the top hull. 88 issues in and it is hard to believe it is almost complete.I did not go too crazy on it.I am working on the mandibles now. Hope you guys enjoy the pics.
The glass actually does not look too bad.
#58 Posted : 11 October 2016 09:15:20
Looking fantastic, well done ThumpUp
#59 Posted : 11 October 2016 11:16:13
It looks amazing. Well done.
Just an observation though -
Would not the weathering streaks and exhaust marks all be parallel, going to the rear as in a rally or F1 car and not sideways, or 'in line' with the radiating panels? On a car or fighter jet, the streaking goes front to back, not across.
The Falcon flies at mega-speed forwards (I would guess) so the streaks etc would all aim straight to the rear.
Not intended in any way as a criticism - an observation intended to be helpful.
A superb model you've built. Amazing.
Roy.
#60 Posted : 11 October 2016 14:00:20
I think the streaks are laser blasts which would be all aimed at the guns.The engines have thrust vectoring so the streaks reflect that.Just made all of that up!!
5 Pages <12345>
This page was generated in 0.165 seconds.
