 Rank: Pro  Groups: Registered
Joined: 18/03/2010 Posts: 121 Points: 359 Location: Waterlooville, Portsmouth. The home of HMS Victory.
At last, thanks to jonny7england I can now hopefully show you my build. I am building her as she stands in Portsmouth today. I am not doing the cut away section but I am aiming to add as much detail as possible. I will probably do a separate diorama with some of the crew and canon from the cut away section. I live in a sheltered flat within a large countryside lodge so she will be far too big to stay with me. My plan is to present her to the lodge for display in their lounge. At present the residents get a fortnightly newsletter on the history of the ship and progress photos of the build. Here's a few photos of the build so far. Caronade12 pounder12 pounder1Water BarrelsThe BowProfileThe Blunt EndHope you like it so far.
Joined: 19/03/2010 Posts: 602 Points: 1,679 Location: Lincs
Water barrels & Blunt end links don't work mate You do not need a parachute to skydive. You only need a parachute to skydive twice.
Built: Golden Star, English Brig. RMS Titanic. (Academy 1/400 Centenary Anniversary Edition) Revell-Monogram 1/48 B-29 Superfortress 1:8 Baron von Richthofen's Fokker Tri-plane. HMS Victory. Nelsons Flag Ship. Sultan Arab Dhow. Artesania Latina Carmen II. The Battleship Yamato. Model Airways Wright Flyer 1:16 Scale. Trumpeter Bismarck 1/200. HMS Sovereign of the Seas. The Black Pearl.
All work now Paul & looking very good mate. What finish did you use on the water barrels? look great You do not need a parachute to skydive. You only need a parachute to skydive twice.
Took some thought that. Anyway I used the Dremmel to cut into the ends of 'em, then with a sharp pencil drew the lines to imitate the strakes. I watered down some walnut brown paint to paint the barrels over the strakes and finally used my 1mm tape blackened with magic marker and stuck it on. 1mm masking tape can be bought on Ebay for £1.90 + £1.00 postage. 1mm Masking Tape (click here)Hope this helps.
All looking brilliant Paul...like the barrels..they look terrific...  Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
Joined: 20/03/2010 Posts: 278 Points: 833 Location: Nottingham
looking good Paul Pam's shipyard is closed for now no more room!
Joined: 24/04/2010 Posts: 108 Points: 342 Location: Croydon
Nice work Paul, very impressed , keep it up mate
looking real good. love the detail on the barrels and the hull planking looks real smooth top job “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
All lower gun ports are now in. Over 3 days work to complete to satisfaction. So the planking continues......    I had a couple of problems with cutting the ports with some of the the glued planks popping when the knife passed through the joint. This was easily rectified by gently lifting the offending plank and dribbling a spot of super glue along the edge with a cocktail stick. I used 15 blades on cutting ports and I used my needle files to square them off. The white spots inside the ports are small scratches on the black paint, I will touch these up later.
Looking good Paul, I have not got as far as you yet, had some issue with where one or two of the planks vary in width, but spotting that Colin had the same problem and his suggestion of rectifying it, I will get back into planking today...Keep the pictures coming mate...  Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
That's the ticket Paul, with us,no pain, no gain really does mean what it says mate... Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
Joined: 30/03/2010 Posts: 126 Points: 335 Location: Bradford West Yorks
nothing to giggle about Paul you have done a superb job its a credit to you especially with your problem hands I have put a few piccys up of my build my problem is I am strapped in a corset and it gets very un comfortable but if i dont wear it I,m in serious trouble with my intestine popping out but thats another story Brilliant work paul keep up the good work Peter
Joined: 25/04/2010 Posts: 748 Points: 2,285 Location: bognor regis
i can assure you paul nobodies giggling it looks great well done cheers benny
Joined: 20/03/2010 Posts: 498 Points: 1,522 Location: South Wales
I'm giggling like mad  Look how clean his desk is!!!! mine was like that, but only on the day it was installed Good work mate, keep it up, you should be proud of what you have achieved so far!!! Ship Builds on the go
Yamato - DeAgostini Subscription - Highly Recommend This Model AKAGI - DeAgostini Subscription - Highly Recommend This Model RMS Titanic Lifeboat (Kind Gift from DeAgostini Crew)
Looking really good!!
Looks well m8, keep it up. On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Joined: 20/04/2010 Posts: 141 Points: 426 Location: Worthing, United Kingdom
Amazing work Paul!  I hope I can get as smooth planking as you have.
paul you are an inspiration to us all,your work is 1st.class and up with the best of them,keep them picies coming. Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
Guest (5)
