fuselage and tail lights Options
m0325
#1 Posted : 05 March 2016 23:35:25
I have received the last pack 12 for the USA. I am a little confused as to the installation of the fuselage lights since I cannot see that the instructions give that information. I understand that the wiring end up at the power box and passes thru via the tubing. I am not sure of the pathway to the power after exiting the tubing.
#2 Posted : 06 March 2016 11:10:13
The cable pathway of the fuselage and tail LED's should be routed towards where the circuit board and battery box are positioned within the underside of the fuselage. Te location ot rhe board and battery box is shown in Steps 11 & 12 of the Stage 125 Pack 12 instructions. Step 12 show's where the plug are inserted on the circuit board.
m0325
#3 Posted : 06 March 2016 15:44:02
Thank you very much
spacejunk
#4 Posted : 07 March 2016 00:08:41
Does the prop motor plug into this board as well? Correct me if I am wrong but the board only seems to have enough plugs for the lights.
#5 Posted : 07 March 2016 09:24:12
Motor is socket #5
spacejunk
#6 Posted : 07 March 2016 09:30:02
Cheers Tomick BigGrin
This page was generated in 0.111 seconds.
