 Rank: Amateur Level 1  Groups: Registered
Joined: 11/09/2010 Posts: 30 Points: 90 Location: Johannesburg, South Africa
Have attached pic of dead-eyes mounted on model of HMS Pandora. Could somebody enlighten me EXACTLY how to fit the bottom dead-eye to the channel re-inforcements? The Constructo assembly instructions not very clear. Thank you Eugene NAUTICAL STUFF: Line – What you feed your spouse in order to obtain funding for additional boat-related purchases .... eugene.lombard attached the following image(s): NEVER play leapfrog with Unicorns !!
that is a covering beading fitted after the deadeyes are fixed.the deadeyes are fixed by a wire frame which surrounds the deadeyes and then fitted to the brass straps,these straps are folded over the ring wire. hope you understand this description.would have been better if you put up a pic of your fittings. Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
Have'nt got to my fittings yet, that's why I have posted a pic of a Pandora I traced on the Internet as an example. Thanks for your response. I am not sure I follow your explanation. Is there perhaps another model I can view where my problem might be viewed in pics, or perhaps some drawings somewhere? NEVER play leapfrog with Unicorns !!
Joined: 20/04/2010 Posts: 545 Points: 1,536 Location: lossiemouth
you drill your channel to take the dead eyes strapes slot the hole so they slip in turn them to face the right way then cover slots with a faceing strip
