What Type Of Super Glue? Options
mrcmos
#1 Posted : 26 February 2016 17:14:16
Rank: Newbie
I finally received all of my packs to start the build. Two year wait, Ugh!
What type and/or brand of super glue should be used?
GYROLASER
#2 Posted : 26 February 2016 18:28:51
Rank: Amateur Level 1
I used loctite precision with the fine applicator as this was ideal to get into the wheel rims between the tyres and worked well for me.
eiseman
#3 Posted : 07 March 2016 03:43:54
I did a search for that but didn't find it. I already bought the following item for this purpose, does it look like it would be commensurate to the loctite?
http://www.amazon.com/Sc...tor-AD124/dp/B004O49F7M
I also found the Bostik one which looks like it might be the best but somewhat expensive unless it is that much better at appluying.
http://smile.amazon.com/...uperglue+fine+applicator
#4 Posted : 07 March 2016 09:29:48
Google cyanoacrylate glue which is the technical term for Superglue
Aquanin
#5 Posted : 07 March 2016 20:53:36
The super glue you bought is fine. I used the same one to super glue the 2nd and 3rd set of tires from the extension pack and it worked well. You might not want to use super glue on the plastic parts like the display front and rear wings as it tends to haze. I used something like this for the plastic, just be careful not to use to much as it melts the plastic together.
http://www.amazon.com/Testors-3...RID=0CA5Z0FAV4MYCX4WGBV4
eiseman
#6 Posted : 08 March 2016 11:24:50
Great, thank you! I'll be very judicious in my application of it.
This page was generated in 0.092 seconds.
